Question about MathRescue Word Problems Of Algebra Lite
Need to find the diagonal of a rectangle. Problem is 5' 3 1/2" x 12' 5 1/4". Do I need to convert the fractions to a decimal? I understand to (a)2 x (b)2 = (c)2. The inches with fraction is my problem! thanks
    President:
  • 1,187 Answers
Ra4942 ,
Yes, you would have to convert the fractions into decimal notation, represented as feet.
Example: 5' 3 1/2" is 5.29167'
By the way, the formula (that you know) is "plus", not "times" ....
a^2 plus b^2 = c^2 (the square of the hypotenuse is the SUM of the squares of the two other sides)
Thanks for using FixYa!
-Gort.
Posted on Oct 14, 2010
Decimal to mixed number fraction
Isolate the integer part (to the left of the decimal point)
Convert the non integer part (decimal part) into a fraction.
Write the result as (integer part) (fraction part)
3/2=1.5
Integer part is 1, decimal part is 0.5
0.5 as a fraction is 1/2
3/2= 1 1/2
Sep 09, 2014 | Texas Instruments TI-83 Plus Calculator
How do I change a percentage to a fraction
Use this http://www.calculatorsoup.com/calculators/math/percent-to-fraction-calculator.php
OR to work it out yourself.....#
How to convert percent to fraction
  1. Divide the percent by 100 to get decimal number.
  2. Count the number of digits (d) to the right of the decimal point of the decimal number.Example: 2.56 has 2 digits to the right of the decimal point, so d=2.
  3. Calculate the factor (f) for making the decimal number an integer: f = 10 to power d
    Example:
    f = 10 power 2 = 100
  4. Multiply and divide the decimal number x by the factor f: x * f / f = y / f
    Example:
    2.56 * 100 / 100 = 256 / 100
  5. Find the greatest common divisor (gcd) of the fraction. Example:
    gcd(256,100) = 4
  6. Reduce the fraction by dividing the numerator and denominator by the gcd value: Example:
    256 / 100 = (256/4) / (100/4) = 64/25
Example One percent is equal to one hundredth:
1% = 1/100
So in order to convert percent to fraction, divide the percent by 100% and reduce the fraction.
For example 56% is equal to 56/100 with gcd=4 is equal to 14/25:
56% = 56/100 = 14/25
Sep 07, 2014 | Office Equipment & Supplies
Fraction to degrees
There must be an error in the question. Could it be fraction to decimal?
The MATH menu has two options 1:>Frac, 2:>Dec.
The first entered on the command line after a fraction keeps the result in (reduced) fraction form. On a displayed result, it converts a decimal into a fraction.
The second 2:>DEC converts a fraction into a decimal number.
The latest OS (2.53MP and following) has a better handling for fractions.
Feb 27, 2012 | Texas Instruments TI-84 Plus Calculator
How do I convert from decimals to fraction with my TI-30X IIS calculator? I need the step by step process
The following examples will demonstrate how to convert decimals into fractions using the TI-30Xa and TI-30Xa Solar. Please be aware that TI-30Xa Solar School Edition calculators do not have this functionality.
Example: Convert .25 to 1/4
- Input .25, press [2nd][<--] (says F<>D above it).
** F<>D means fraction to decimal, decimal to fraction.
Example: Convert 1.38 to 1_19/50
- Input 1.38, press [2nd][<--].
Example: Convert 9.75 to 9_3/4
- Input 9.75, press [2nd]{<--].
Mar 08, 2011 | Texas Instruments TI-30XA Calculator
How to convert a fraction into a decimal
First put the calculator in degree mode.
To convert from fraction to a decimal number first enter your fraction or, mixed number. I'll convert a mixed number to a fraction first since, I don't have a key for the symbol that shows that a number is a fraction on my keyboard. Example: [3][A b/c][1][A b/c][2][A b/cd/e][ENTER]
3/2 should be entered at the home screen. While at the Home screen enter, [2nd][FD][ENTER]
1.5 should now be displayed at the Home screen.
As you can see it is really just using the [A b/c] key to enter in your fraction and, [FD] key to do the converting. The [A_b/cd/e] key isn't necessary because, mixed numbers will convert to decimal numbers just like fractions do. I just don't have the key to show a fraction symbol that the calculator uses. So to show that symbol, I used the / symbol with the fraction number.
Dec 29, 2010 | Texas Instruments TI-30 XIIS Calculator
How do i convert Decimals to fractions on the TI30X IIs calculator. I need the Button sequence Please!
2nd [F<>D]. F<>D is on the PRB  key, diagonally down and right of the 2nd key. The conversion may not work for numbers with more than three nonzero digits to the right of the decimal point.
Aug 19, 2010 | Texas Instruments TI-30XA Calculator
How to convert fraction to decimal
You can convert between Standard Form (with fractions and pi) or Decimal form by using the "S<->D" button. Use Mode 1 if you mostly prefer fraction answers and you can use the SD button to convert to decimal or use Mode 2 if you mostly prefer decimal answers and use the SD button to see the fraction.
I hope this helps and good luck!
Please remember to vote 51218db.jpg Thanks.
Oct 31, 2009 | Casio FX-115ES Scientific Calculator
Cant get answers in decimal format, I would like to set up my casio fx83es so that the answer is in decimal format all the time.
To make sure that results are always in decimal format, put a decimal mark (point) at the end of one integer.
ex: 1./2 or 1/2. or 1./2. display as 0.5, so does 1. + 1/2
To convert from decimal to fraction and from fraction to decimal press a b/c
To convert from proper to improper fractions use [SHIFT][d/c]
Hope it helps.
Oct 04, 2009 | Casio fx-300ES Calculator
I need to convert decimals to fractions
Press [MATH][1:ToFrac] to convert an aswer to fraction.
If you enter 18.52[ToFrac] [ENTER gives 463/25
[MATH][2:ToDEC] converts a fraction to a decimal number.
Hope it helps.
Sep 22, 2009 | Texas Instruments TI-84 Plus Silver...
HOW TO INTER FRACTION ON A TI-83
Once you enter a fraction the calculator calculates it and displays a decimal result.So basically you cannot do fraction manipulations. However you can convert a decimal result into a fraction. To do the conversion, you enter the decimal number then you Press [MATH] and [1]. ( -->Frac) The number will be converted.
Similarly you can enter a fraction to a decimal number (-->Dec)
[MATH] [2:] [ENTER]. But I see no point in doing that, because any fraction entered is displayed as a decimal number.
Hope it helps
Sep 03, 2009 | Texas Instruments Office Equipment &...
Computers & Internet Logo
192 people viewed this question
Top MathRescue Computers & Internet Experts
Computer Links
Piyal Perera
Piyal Perera
raysaw
Are you a MathRescue Computer and Internet Expert? Answer questions, earn points and help others
