Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
I put a new lamp in last week. on the screen it ask me push enter so i did and the sentence went off the screen and the tv has worked good. now it is asking the same thing and i push enter and the sentence on the screen clears but the tv turn itself off in about 3 minutes what do i do
    Sergeant:
  • 171 Answers
Reset the TV set, infront of your TV where the LED lights are there is a small reset botton that you can push with the tip of a pencil ot pen hold this botton down for 10-15 seconds then unplug the TV set and let it sit for about a 1 or 2 hours
then turn it back on it should work and if the TV still turns of after a few minutes you might have
a ballast issue sence you already replaced the lamp
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Posted on Oct 14, 2010
I've had this tv for 4 years. About a week ago, the top half of the screen went black..i think the top went out, but im not sure.
Unfortunately it's time for a new set. the lamp ha s gone and the cost to fix will be the same if not more than to buy a new one..good luck
May 04, 2010 | RCA TruFlat 27F520T 27" TV
Got a pop last week & t.v went off. Replaced lamp and it acts like it wants to come on but all 3 indicator lights blink and then it shuts off. the lamp doesn't fire up so the screen stays black
It seems like your ballast doesn't have enough voltage to keep up with your new lamp, the best thing to do here is to replace the lamp, you should be good after that.
Jul 13, 2009 | Samsung Televison & Video
Burning out lamps on my 65inch dlp
I have 65" Mits. lamp lasted about 2+ years and burned out. bought new on internet, that lasted about 5 months and went. Got free replacement and that lasted about 4 months. No more free replacements ...
Bought new from different source and it burned out in a week.
Note: These were ALL OSRAM original lamps from reputable suppliers.
They sent a new one but also cautioned about cleaning the "filter" on the lamp housing. NOT the large screens on either side, but the small rectangular one (about 3/4" x 2"). I did this with a shop vac pulling and pushing from every angle and it was really clogged almost solid. No way air was going across the bulb to cool it.
THIS IS CRUCIAL and I feel is the keys to the kingdom! I did this and voila - no more "plastic smell" when installing the new lamp and everything's great!
I feel that Mits should be held accountable for this for not recommending the lamp housing be cleaned periodically (maybe yearly). I really feel if this were done with my original one it would have last a lot longer.
Lou
Dec 14, 2008 | Mitsubishi Televison & Video
Mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
I have Mitsubishi WD-62525. Last week I turned TV on and there was no picture, on green horizontal lines across the screen. The picture then went black and I only have sound. The lamp indicator lite turned...
that is a common problem with that model you will need the v26 power pwb repair kit and the V26 FMT pwb repair kit. You can get both kits at the following link which includes the replacement capacitors and instructions on where the capacitors are located. Heres the link.
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi Televison & Video
Pop then dark screen - no picture... New lamp installed and still no picture
Yes you are correct, I have seen this many times. 6 flashes is the thermal fuse
Mar 14, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF-46E2000 - Screen Goes Blank
Ok, the solution for all our problems is in fact the lamp. I finally replaced my lamp and no problems to report. Sony should do something about this because I know I didn't have 8,000 hours on the lamp and it sounds like no one else has either. I tell you what, I'm NEVER buying another Sony product ever again. Not only did I have this problem but I bought a Sony Blu-Ray disc dvd player and I've had nothing but problems out of it. I keep getting firmware updates for it but it doesn't help and recently I bought a Sony Walkman MP3 player and for no reason it quit working, it would power up and immediately power off. Sony did replace it though (but of course it was only $70 compared to the prices of the tv and dvd player).
Anyway, if you are still having problems with your tv, the lamp door is on the right side, pop it open and there will be another door with a knob on it. Turn that knob counter clockwise to unlock it and pull it out. Inside that door you will see the handle for the lamp, put your finger through the loop and pull up and out at the same time, to put in the new lamp, push lamp straight in until it won't go in any further and puch down, it should then be locked in place. Replace both inner door and outer door and you are good to go.
Someone mentioned something about cleaning the dust from around the lamp. I tried that before I got my new lamp. It only worked for a day and gave out again. Hope this helps.
Mar 02, 2008 | Televison & Video
TV Problem
It is a failure in the light engine itself. You will need to have it replaced. Here is a link to that rather costly part. http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/50V500/Hitachi+Ltd/Hitachi/UX22201D/New.aspx
Apr 05, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
