Question about Cooktops
Ignis Gas Hob AKL700
Does the manufacturer recommend fitting this appliance with a flexible coupling?
No. not in the uk. a fixed appliance must have a rigid pipe connection with a means of disconnecting/isolating. you must not use a flexible pipe.
pete
Posted on Jul 22, 2008
What type of pipe do i need to by for connecting necht gas hob to my gas
Usually it is a flexible pipe with a gas clip connector on the wall end and a standard thread on the cooker end. In the UK we employ Gas Safe technicians to install gas appliances due to leaks and possible explosions caused by an unsafe installation.
Feb 04, 2017 | Cooktops
Hob igniter not working
Handbooks are available from Miele online. If that doesn't give an answer, you may need an appliance service person. I don't recommend you poke around yourself unless competent with gas and electrics.
Jul 21, 2014 | Miele Cooktops
I have a gas odour below the Miele Gas Hob.
Call your gas company again. What you don't want is an explosion! PDQ!!!
Nov 27, 2012 | Cooktops
I have a Neff 5 burner hob. The middle burner will not stay lit. A small amount of gas runs around the grey gas dispenser while trying to light the hob with the igniter depressed. It then fizzles out...
Some gas appliances have a thermal couple. it could be dirty at its base connection. If possible clean that area with alcohol
always unplug electricity before attempting to repair on any electrical appliance .
Sep 08, 2017 | Neff Cooktops
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
Trying to get hold of a fitting instruction leaflet plus list of spare parts for a gas hob code no. E4NE T2484SOEU/01
Why do you need a fitting manual ? Any competent gas engineer should know the contents of BS6172 / BS6891 which both apply to the fitting of domestic gas cookers / hobs. What spares do you need. You can get a spares inventory from Neff. Ensure that it is the correct appliance for the fuel gas you are connecting to. The jet sizes for LPG & Natural Gas are very different.
Apr 16, 2009 | Neff T2346 Gas Cooktop
Installing Smeg Gas Hob PGF75-3 Ultra Low Profile.
yes u can install it at the top of the drawers but check the gas connection before closing the drawers to make sure ther no problem,the inlet gas connection is in rigth side facing to u.
Nov 28, 2008 | Smeg Cooktops
Gas Hob Flame
Hello
Tha sounds to me like the air mixture nedds to be adjusted on the stove, It's not difficult to do, just rotate it until the flames loose the yellow or your pans will be stained with soot.
The should be by the fittings (convertion fittings), you know?
LP Gas to Natural Gas or Natural Gas to LP Gas.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 30, 2008 | Cooktops
Burner/Flame
Hiya .. this could be due to a number of problems...... has the burner ever worked correctly?
Is the behaviour with only one ring?
1. If not... then it could be that the pipework to the hob itself has not been recuced sufficiently enough in pipe diameter to the regulator far enough back ...
2.The regulator is faulty... in which case it can be replaced... however consider the cost of a new regulator and labour to fix it .. against the cost of a whole new hob... which should include a regulator. Is the hob still under warranty... if so use that .. but you will normally have to provide some proof it has been fitted by someone suitably qualified.
3.the regulator may never have been fitted, which is dangerous and bad practice.
Either of these scenarios... please ensure that you use a suitably qualified gas engineeer... I dont wish to be alarmist... but gas leaks and faulty gas appliances do cause unnecessary deaths...and is a silent killer.
Regards Faggly
Mar 26, 2008 | Maytag MGC5430 Gas Cooktop
Cooktops Logo
173 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
