Question about Nokia 1100
Nokia 1100 not charging
Changed the charger and the charge port still not charging at all
What could be the reason
  • Anonymous Jun 02, 2008
    same problem it sucks
    New Friend:
My nokia1100 not charging suptet plz help me thank you
Posted on Aug 18, 2013
    Sergeant:
    Champion:
  • 359 Answers
Possible the battery or the charge port itself a phone shop should be able to test it for free
Posted on Jun 03, 2008
1108notcharging
Hi, when a phone does not charge, Usually is either from the charger or the charging port of the phone that is bad.
Use the charger on another nokia phone to see if it will charge. If it does charge on another phone, that means the charger is working,but the charging port is not.The charging port is located below the phone where the charger is been inserted.
It"s very easy to replace.when you unscrew the phone,remove the phone board,the charging port is removable,just buy another charging port,and replace and you are done.
Take care.
Oct 05, 2010 | Nokia 1100
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 01, 2010 | Nokia 1100
My 1100 mobile phone showa not charging
There are several reasons, like bad battery, bad charging connector, bad charger, charging pin problem, charging ic, etc..
You need to try with another charger and with another battery. If changing the charger and battery don't help, follow the instructions below;
First, remove the battery, clean the contact points on the battery and also clean the battery interfaces on the mobile. You also need to check the charging connector and clean whatever is possible. Use soft brush or cotton with Ipa solution or alcohol/spirit/acetone to clean all the metal contacts. Try charging again.
If the above method don't help, you need to change the charging pin;
Still the problem persists, then check the charging ic. Perhaps jumpering will be necessary.
If you are not sure what you gonna do with ic, I don't recommend to play around with it, rather take it to a mobile repairing shop or nokia service center and get it fixed. You may damage another components.
I wish you good luck.
Thanks for using FixYa.
Jul 24, 2010 | Nokia 1100
Not charging
Have you try to use another similar charger to charge it to see if it will charge, if you have and yet, it did not charge, it means the charging port is bad.
The problem with your phone is that the charging port of your phone is bad and will need to be change in other for your phone to charge.
All you need do is change the charging port of your phone and you will see that your phone will charge.
Take care.
May 15, 2010 | Nokia 1100
Not charging
Have you use another charger to charge it to see if it will charge?
If you have and it is not still charging, it means the charging port of your phone is bad and will need to be replaced.
Replace the charging port and you will see that you phone will charge.
Regards.
Apr 25, 2010 | Nokia 1100
Not charging
firstly, test the phone with another charger, to be sure the charger is not the cause of the problem.
Once you have confirmed that the charger is not the cause of the problem, then you will need to change your phone's charging port.
There are basically to reasons for your phone not to charge. Its either the charger of the phone's charging port as stated above.
You also have an option of using a desktop charger to charge your battery, in case you are not ready to change the charging port yet.
Good luck.
Apr 20, 2010 | Nokia 6300 Cellular Phone
I have a nokia 1100 with charging problam
Hi there
The problem is from the charging port,
You will have to change the port so that you will stop having the charging problem
A repairer can change it for you if you cant do it yourself
Thank you for visiting fixya
Feb 27, 2010 | Nokia 1100
Not charging for nokia 1100
when u conect charger if its shows NOT CHARGING,, its uem fault and u cant change uem. its better to use universal charger
Aug 11, 2008 | Nokia 1100
Nokia 3250 charging problem
it sounds like a problem with the charging port (where you actually plug the charger into your phone). unfortunately, you may have to replace the phone, as switching batteries or chargers wont solve the problem.
Sep 24, 2007 | Nokia 1100
Nokia 1100 Logo
90 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
