Question about Canon imageCLASS MF8180C All-In-One Laser Printer
Scanner not working on Canon MF8180C
Running Vista 64 on the Canon MF8180C. Downloaded drivers from Canon site. The printer and fax are working, the scanner doesn't seem to be recognised though, anyone had similar problems and found a solution.
  • 3 more comments
  • anythingnew Jul 31, 2008
    Hi thanks for a solution, I'm currently using a USB cable for connection, any other ideas.
  • chris_joss Nov 05, 2008
    I have exactly the same problem.
    Canon told me they didn't have any solutions.
    Perhaps we must wait Canon to make TWAIN application which recignizes it...
  • sdabek Dec 01, 2008
    I have indentical problem with cannon mf5770! I am using usb cable and still doesnt work
  • Anonymous Dec 15, 2008
    Same here. Very frustrating since the Microsoft Vista compatibility web site shows it as being compatible.
  • Anonymous Mar 23, 2014
    Scanner will not work
We had this when using the printer via network cables. The scanner only works with a USB cable and the setup orgram won't recognise until then.
Posted on Jun 10, 2008
Since upgrading to windows 7 the canon mf8180 printer is working but I can no longer use the USB connected scanner.
The Canon 8180 will work with Windows 7 32 bit operating systems only. Their latest ToolBox drivers will also get the USB connected scanner to function. 64 bit Windows 7 users are simply out of luck as the printer is not compatible. Drivers are on Canon's site and easy to access.
Dec 29, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
I'm running Windows7 x64bit, downloaded the driver for the printer and fax, but the scanner is not working, I can't find how to make it work
I just called Canon. They said they don't have the scanner driver for Windows 7 x64. It is in development, but could not give me a time frame when it would be done. They suggested checking back on their website periodically.
Jan 06, 2010 | Canon imageCLASS MF3240 All-In-One Laser...
Canon MF 8180c - MFToolbox does not find scanner on Vista 64bit
Hi ...
As per my knowledge, MFToolbox does not work with Windows Vista 64 bit ....
But just to be absolutely sure about it, I checked for this information in multiple locations including canon official website but got the same answer ... it does not work with Windows Vista 64 bit ...
I know I can't help to resolve your issue ... But do vote ...
Cheers ... :)
Jul 26, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Vista 64 bit os will not install my canon mf3200 printer
Most of the software nowadays are only works for 32Bit operating system, you could try to check the availability of 64bit driver of your Printer from the manufacturer's web site.
Mar 14, 2009 | Canon MF8180C Color Laser MFC Printer
Problem in canon
i found a solution for printing with Canon MF 3110
1- Download Driver For MF5730/5750/5770 For Vista 64-Bit
File Name : L7602ENx.exe
http://software.canon-europe.com/products/0010260.asp
Follow These Steps
1- Add Printer
2- add a local printer
3- Use an existing Port : Choose : USB ( Virtual Printer for USB )
4- Have Disk
5- Locate the File Name : MF5700AK.inf
6- Printer Name : Change From Canon MF5700 Series To Canon MF3110 Series
7- Print Test Page
it Work for me on Vista Home Premium SP1 64-Bit
P.s
still Cant Manage to use the Toolbox 4.9.1.1.mf04 for Scanning ( Any Ideas ? )
Oct 22, 2008 | Canon MF3110 All-In-One Laser Printer
Scanner
You need to uninstall the existing driver first and reboot the computer then try downloading the vista driver and install it back that should take care of the issue.
Regards
Sep 18, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Canoscan 4200f Problem with Vista 32 bit
I got mine working after experiencing the same problem.
I had mine hooked up to a USB hub, after I hooked it directly to the USB ports in the back of my computer, everything just worked fine.
Weird that it worked on the USB hub on XP and not vista though.
Dec 31, 2007 | Canon CanoScan 4200F Flatbed Scanner
Canon imageCLASS  MF8180C All-In-One Laser Printer Logo
1,875 people viewed this question
old marine
old marine
