Question about Amana ARSE665BS Side by Side Refrigerator
I have an Amana ARSE665BC side by side. It worked perfect when it was in my kitchen. I moved it to my garage and plugged it in less than a half hour after moving it. It no longer get cold enough to keep food frozen and the fridge section gets to about 50. Also in the freezer there is some frost near the bottom. Any ideas!
catriver
  • 878 Answers
SOURCE: Amana bottom freezer/ refrigerator
Geezer, sounds like a defrost issue. I usually find the bi-metal to be the culprit on this model. Check out the pic. You will have to remove the back panel in the freezer and defrost the evaporator. Remove the ice maker if there is one. The back cover has 4 quarter inch screws. remove those. The air vent has 2 plastic clips one each side and one on the bottom, push in and pull the grill off. The thermistor cover has a slot for a flat blade screw driver,push in and pull the cover off. The thermistor will now slide behind the back panel. Check the bi-metal for buldging. As long as the evaporator fan is working, it's probably a defrost problem.
Posted on Jul 16, 2007
rapid4
SOURCE: GE TPX24BPBGBB fresh food section won't cool
Have you noticed any ice built up on the rear freezer wall? it is very likely that you have a defrost problem situation,IE: Heater,Defrost Thermostat,Defrost Timer any failure in these components will cause an icing problem and therefore you will not get sufficient air flow to the Food Compartment
Posted on Sep 20, 2007
VtToolMan
  • 704 Answers
SOURCE: Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Posted on Aug 03, 2009
SOURCE: Fridge not getting cold enough
The cold from the freezer is piped up to the refrigerator and if that tube gets clogged with frost or ice it will not be able to blow to the cold air into the refrigerator area. I took everything out, unpluged the unit for about 6 hours, till all the frost from the freezer was gone, wiped up all moisture and turn it back on. It worked!
Posted on Aug 04, 2009
mgprice
  • 744 Answers
SOURCE: Freezer frosty and fridge warm.
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using fixya! Mike
Posted on Oct 09, 2009
We moved an Amana Fridge on it's side...how long should we wait before plugging it back in?
Anything with a compressor in it should always be left for 24 hours standing upright then you can plug it in
Mar 26, 2012 | Amana ABB1927DE Bottom Freezer...
Door closes but opens inmediatelly and partially,only 1 foot and a half
With the garage door up pull the release cord to disingage the garage door it self in the up position. You can skip the disengaging step, But,It saves ware and tear on the motor.
Then using a step stool you will find limit adjusting plastic slots/screws on the side of the opener.
The left screw is for garage door down.
I would turn the left screw clockwise 1/2 turn or less. then activate the remote opener. noting which way the latching mechanism moved. and so on.
It may take a few adjustments with this proceedure to get it perfectly closed. Then activate the remote to re-engage the garage door it self.
Also, LiftMaster has a web site that you can check out.
Jul 23, 2011 | liftmaster Garage Door Limit Switch...
Have an Amana 85088 P1109007W that worked fine for 18 year just bought a new one and moved the Amana out to the garage to use as a second frig .We cleaned it and plugged it in , it cooled for about 10 min...
It may be in defrost mode. Look at the temp control on the underside for a hole with no
screw in it that appears to serve no purpose. Using a flathead screwdriver, turn the
mechanism inside the hole, (it is the defrost timer) and see if the unit comes on. If no
luck, then replace the start relay which is located under the plastic cover on the side of
the compressor. It plugs onto the compressor on three pins, if no replacement is available
they make a "universal" start kit for about 8 dollars which plugs onto these pins and has
good instructions. Model and serial number are usually inside the fresh food compartment
on the left side. The appliance parts store should have this item readily available.
Hope this helps :) remember to unplug unit before replacing any parts.
Jul 18, 2011 | Refrigerators
Bought used and had to lay on it's side to transport to home. I left it off for a couple of house, but it isn't cooling. I hear the fan, on the freezer side, but very little air and not very cold coming...
Here is a tip that I wrote on moving refrigerators...if you did not do it this way then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is the best way
If you already have moved it wrong, you can sometimes get it working by plugging it in and unplugging it a number of times with an hour or so in between.
heatman101
Nov 17, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Moved this refregerator to another house. it runs but done not cool or freeze. it did at previous house.
heatman101
Sep 26, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Amana gas oven not working
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Aug 30, 2009 | Amana ARGS7650SS Gas Kitchen Range
Fridge not cooling
Hello.
The most common thing that happens while moving a frig is when moving it they put the dolly underneath the condenser fan housing and bend it into the fan causing the compressor to overheat before it has a chance to cool down everything. If this isn't the case then I will send you a list of things to check out. Let me know.
Dec 07, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Bizarre Refrigerator Problems
If your voltage is around 117v.you are okay.Any time you lose cold air except the freezer you probably need to check your evaporator thermostat and your heater.
Sep 15, 2008 | Samsung RS2556 Side by Side Refrigerator
Amana ARSE665BS Side by Side Refrigerator Logo
76 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
