Question about Miele Washing Machines
I have a miele w5256 and the problem lights are flashing - check drain and outlet. I have checked these and the lights are still on, what can i do next?
  • 868 Answers
Check harness connectors starting at the control board,make sure none have come loose.
Posted on Jun 02, 2008
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
Premier 300 Not spinning
Check if the drain hose is blocked. Check the wires aren't loose on the drain pump. If all that's ok you will need to replace the drain pump.
Jul 08, 2013 | Miele Novotronic Premier 500 Front Load...
The diswashing programme starts intermittently and does not go to the end of the washing programme and the washing is luke warm. I have checked and cleaned all filters and checked the water...
I suspect the pump or outlet hose is partially blocked, is it emptying in normal time with a normal outlet flow? (You can check that by watching the water come out if you can see the drain). Does the flashing light have a label on it, the lights on miele are generally labelled.
When you say it starts intermittently do you mean you have to start it more than once to be successful? That again would point to a pump or outlet hose blockage as it has to purge any water before starting.
Difficult to diagnose without more clues.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | Miele Dishwashers
Inlet/outlet light keeps flashing on G641 dishwasher - have checked filter and cleared debris. Just completed a wash but dishes not washed or rinsed adequately. Anything else I can check before requesting...
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a
laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely. See what part of the cycle the unit lights up the fault. If it happens at the very start it is the drain. If it drains ok then fails it is the inlet. If it fails after that it could be any number of things.
Hope this helps.
Jan 26, 2010 | Miele 24 in. Novotronic G641 Plus Built-In...
Red light flashes when it gets to rinse cycle
complain to miele be a pain they have given discounts on a new one before. try running apple cyder vinager through it pore some in let it run a little then open the door and let it soak for a day or so and then try it again it may just be dirty good luck
Dec 08, 2009 | Miele 23 in. Novotronic G841 Built-In...
Miele Intake/Drain light on/flashing and the dishwasher just shuts down.
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage.
Hope this helps.
Nov 22, 2009 | Miele 23 in. Novotronic G841 Built-In...
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Sep 05, 2009 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
158 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
