Question about Philips 26PF9946 26 in. LCD Television
Philips 26" LCD 26PF8946/12
Firts sight of a problem was when the screen displayed a single black line across horizontally, about one third up the screen.Then it got wosre and the picture blacked out then went white then all the colours of the rainbow started to appear. it was nice to watch as the full spectrum of colours constantly blended and changed but obviously not a good scenario. The set is just over 3 yers old no other probems up to now. Any ideas on what is causing it and is it repairable ? thanks JC2
  • herman1945 Jul 27, 2008
    My display went bad also after 2,5 years, on the right top of the cabinet the TV gets really hot. Now at this place you get a vertical beam of colours when the TV is hot.
    I think there is a heat problem in this type of TV, there the display control is at this location with 14 coils on it=, which create a lot of heat. The inside and outside cabinet is closed on the top, so the heat can not escape.
    Please let me know if there are more simular problems with this TV !
  • Anonymous Aug 14, 2008
    hello, i have the same ploblem after 3 year old of my TV.
    There is a vertical right band of colours that appear in any moment.
    My TV is very hot too. I think that can be a temperature problem.
SOURCE: LCD Philips 26pf8946 after about 45mins right hand 1/3rd picture not viewable
Hi Darnez,
It sound like to me that one of the boards that power the bad side of the screen is getting hot and quitting. The boards are not too expensive to replace but getting them is generally the big problem. ( At least for our company). The set would be worth tkaing to a local shop and have it looked at, but replacement costs are going down every day it seems.
Good Luck
I hope in some way this has helped
Ed Meshechek
NC Electronic
Mills, Wyoming
307-266-4675
Posted on May 28, 2008
  • 7 Answers
SOURCE: 42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Posted on Jun 07, 2008
  • 2336 Answers
SOURCE: Picture Problems On 50 Inch Philips Plasma
You plasma still under manufacturers warranty. Most electronic devices have one year warranty.
The failure in your TV can only be corrected by repairing it.
I would suggest to call philips and ask them to find you an authorized repair center near you to get your TV fix under their warranty.
Posted on Jul 24, 2008
  • 138 Answers
SOURCE: Dozens of horizontal lines across display!! HELP!!!
Bring up the menu and if the lines are not on the menu replace the small signal board that is your video prossor. If the lines are still the replace the Y main board that contrl the top half of the screen.
Posted on Aug 20, 2008
  • 231 Answers
SOURCE: I have a Philips plasma 42 with black lines across the screen
I would first check if there is an available firmware upgrade for your model .Upgrade requires you to download firmware from philips website.Then transfer it to a memory stick .Then use a memory stick reader to plug into tv for firmware upgrade.Other wise the set would probably need repair .Possible a bad SSB board or another issue
Posted on Aug 26, 2009
A light horizontal line has appeared on my Samsung UN55C6500 TV. Is there a fix for this?
Horizontal lines on LCD TV,
not usually repairable
plasma may have a corroded or dirty connection on ribbon cable left side of TV looking from the rear
Apr 25, 2017 | Samsung Televison & Video
Red and yellow horizontal lines on the last third of the screen
3 Options
LCD damaged
Flex cable from MB to LCD
Graphic card damaged
First try to connect the laptop to a external screen...its ok???
Remove the lcd and try another one...its ok???
If not....change the flex....its ok?
If not...only one option...graphic card (GPU)
Feb 26, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
I have 5 white dotted lines running horizontally across my nuvi1490lmt. Does anybody know why this would be?
Yes, this is caused by a defective LCD display, There is nothing that you can do to make them go away. It is caused by a defective transistor in the LCD display logic that is either stuck on or off. The transistor controls a single horizontal line across the screen. The only way to fix this problem is to replace the display.
http://www.sharc.net/gps_LCD_repair.htm
Oct 26, 2013 | Garmin nuvi 1490T GPS Receiver
Black lines running across the sony ericssons w580i screen
if only vertical or horizontal line across you LCD display
your LCD need to be replaced.
your LCD cannot be fix.
Mar 07, 2011 | Sony Ericsson W850i Cellular Phone
Single horizontal line
this problem is field collapse usually causd either by the field oscillator or field output stage to advise you further i would need to look at the circuit diagram
Feb 09, 2009 | Philips Magnavox 27MS343S 27" TV
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Black horizontal line
The LC display is bad. The monitor will have to be replaced.
Jun 24, 2007 | HP vs15 15"LCD Flat Panel Monitor
Philips 26PF9946 26 in. LCD Television Logo
341 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
