Question about LG WM-2277HW Front Load Washer
Only works with cold water - LG WM-2277HW Front Load Washer
    President:
  • 2,468 Answers
Check the cold water inlet hose screen for blockage from hard water residue,if its not plugged,then it could be the cold water solenoid valve that opens and closes the water supply and is controlled by the machine
Posted on Oct 14, 2010
I HAVE A ZANUSSI AQUACYCLE WASHING MACHINE ZWF1221W. IT WORKs THROUGH THE WASH BUT JUST BUZZES ON THE RINSE CYCLE. I CAN TURN IT TO SPIN & EMPTY AND THAT WORKS AS WELL.
clair you may have a cold water problem, it may have filled with hot water and gone through wash cycle but as it got to rince it only fills with cold water ,the buzzing may be the cold water solenoid staying open and if there is no water passing through it will make a buzzing noise,
1.check the cold water valve # is on . it's what the blue /cold hose is connected to, also in some hoses there is a filter ,it's possible it could be blocked but unlikely.
2. check the cold water hose has not bend in half from the wall valve to the washing machine,this will stop the water flowing.
3. or it's possible you could have a faulty cold water solenoid valve.**
cold water pipe on wall> water valve# > blue cold water hose > * *cold water solenoid valve on machine.
Nov 14, 2016 | Zanussi Washing Machines
Cold water cycle does not work. Can get only hot water when cold water cycle is run
Swap the hoses around on the Hot & Cold water Taps to prove that the Cold water Solenoid is not working.
Could be electrical from program timer or
The Needle or Diaphragm inside the Valve section of the Solenoid.
Take apart the solenoid & clean it.
Jul 08, 2015 | Washing Machines
I have a Samsung WA13G7Q1 washing machice The
the quection is not complete, when the cold water inlet and hot water inlet both work then what is the problem....
Apr 27, 2010 | Samsung Washing Machines
Whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Sep 12, 2009 | Washing Machines
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
I have a PUR 200 water filter/hot and cold dispenser and the cold
I have the same problem as both stated earlier. The cold water is not working and the night light does not work.
Jan 21, 2009 | PUR Air Purifiers
Does Not Rinse
Check each temperature during initial wash fill. Set to hot water, is hot water coming out? Set to cold water, is cold water coming out? The rinse cycle is cold only. If cold water is not working machine will just stop at rinse.
If cold water not working:
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still not working, replace valve.
Jun 14, 2008 | Whirlpool LSR6332K Top Load Washer
Cold stopped working
Check the strainer in the cold water inlet line. Make sure it is not plugged. Then,put the cold water line into a bucket and open the valve slowly until water comes out. If water flows freely, it's probably the cold water solenoid. It's pretty easy to replace.
If not, check all valves upstream, check for a collapsed hose, or mineral build up in the pipe (galvanized pipe)
Mar 04, 2008 | GE DBSR453EBWW Electric Dryer
LG WM-2277HW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
