Question about Whirlpool Washing Machines
Whirlpool duet sport washer code f-25 what does that mean?
  • 2,272 Answers
The error code f-25.This error code indicates that the motor is having difficulty turning. Try this to remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
But if this procedure is also not helping then motor has to be checked manually.If anything blocking the tor from running then it has to be cleared but if there is no blocking to motor then its weak./faulty motor causing this problem.Check the motor wires and connections also to confirm the fault. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU). -------- For all other error related to your washing machine.Please click on the link directly. http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html ----------- Unplug the machine and take the top off. You will see a central control board either on the right side or backside of the unit.Inspect for any corrosion. Remove the bottom panel below the door. Down below you will see the MCU board control. ------ To get required parts you can get it from www.repairclinic.com.----------- Keep updated for any more queries.Thanks.
Posted on Oct 14, 2010
Whirlpool duet sport washer error code f-24
check lint trap. probably clogged take front bottom kick panel off under door takes a torx - 25 mm i think and also there should be a paper in there with codes and instructions.
Mar 24, 2013 | Whirlpool Washing Machines
F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does f-24 mean?
inside the machine should be repairmans instructions. this includes explanations for all the error codes.
you will have to remove the front access panel
May 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer displaying a fault code.
check your manual. it will tell you what it means and what to do
Apr 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool duet f13 error code
hi there
i read your report heres the site for your codes
Whirlpool Duet Washer Error Codes Topic: Whirlpool Duet Washer Error Codes (Read 5660 times) ... Whirlpool Duet Washer Error Codes " on: September 13, 2008, 10:38:25 PM " Logged. John Pahl ... appliancejunk.com/forums/index.php?topic=1785.0 - 81k - Cached
ty for writing to fix ya
best regards Richard
Dec 01, 2009 | Whirlpool Washing Machines
Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
766 people viewed this question
Dan Webster
Dan Webster
Sal De
