Question about SanDisk Sansa e260 MP3 Player
My mp3 will not charge
I have a sansa e260 and i broke a needle inside the charging port by aciddent and now i cant charge my mp3 anymore. I there something i can do. Also is there a desktop charger for the battery in the sansa e260.
  • 981 Answers
Eh, probably keep the needles well stowed in the future, and a silicone plug (if you have some spare all-silicone caulk...) in the port at the Sansa's base. You can of course repair or replace the socket; the easiest way is to find the wiring correspondence on the charger cable to the USB port (using a DVM in continuity test mode...and needles, but little force) and concentrate on restoring the position of those contacts so it recharges, epoxying things into place.
Try posting a (link to a) photo of the port, if that's easy for you.
Using a charger for the battery that has you unscrewing it often sounds unsettling, but of course you can. Interstate Battery and such can probably let you on to what they use (it's probably what I see on eBay for $40ish when I search for Li Polymer battery charger .
The low-cost way is to look at the charger descriptions at (e.g.,C1,C1003,C1037,C1078,P9551 or ) and buy that or a similar product and support components from an components vendor like or Electronics Goldmine, or a local store that has those things, building it to plug onto a spare USB header or port on a computer. You just want to match the charger type to the battery chemistry (LiMH or Li____ will be on the battery as a hint) and rely on the chip to handle all the charging current the smallish battery can take on.
Posted on Jun 03, 2008
My sansa mp3 will not charge on my computer it just drains the battery instead. I have tried rebooting my computer but it still will not I miss my music !!
Not all computer USB ports put out enough current to charge the battery. If you're plugging the Sansa into a USB hub, try plugging it in directly. If there's another USB port available, try that.
If that doesn't work, you may have to get a separate USB charger, as used for some cell phones.
Also, bear in mind that when the Sansa is connected to a computer, you can't listen to your music on it.
Oct 21, 2010 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
Sansa Repair Website?
I can only charge my Sansa Sandisk but I cant put any songs on it? is there a solution for this problem?
Sep 06, 2008 | SanDisk Sansa e200 MP3 Player
Mp3 player won't turn on/won't charge
make sure the hold switch is in the unlocked position. otherwise the player will not charge or be recognized w/ the USB port plugged in.
Jul 10, 2008 | SanDisk Sansa e260 MP3 Player
Your USB port must be repaired. In the meantime, hopefully, your computer has another USB port that you can use. Battery is a replaceable lithium ion rechargeable battery. There are battery chargers that you can connect to wall outlets - the type that plug into the computer would probably require that you plug it into the USB port, which you said is broken - so that's a no-go. There are multiple vendors for battery chargers - one possibility is
-Tha Mp3 Doctor
Jun 02, 2008 | SanDisk Sansa e260 MP3 Player
My mp3 player port
Ohhh - you broke the port on the mp3 player itself - must be replaced - cannot be repaired for less than the cost of a new Mp3 player.
The battery can also be charged using an AC adapter (not included) or a car
adapter (not included) and you will be able to play your device while
charging with one of the adapters. The battery will reach approximately 70%
charge in 2.5 hours and full charge in about 3.5 hours.
-Tha Mp3 Doctor
Jun 01, 2008 | SanDisk Sansa e260 MP3 Player
My Mp3 player cant charge
No - I know you may rate me poorly for this. But there is definitely not a wireless charger for this - i'm not guessing - it's a fact.
May 30, 2008 | SanDisk Sansa e260 MP3 Player
Problem with sansa e260
that happens to me too. i think the problem is that your computer can't like, sense that it's plugged in, so your battery's dying out, and the computer wont charge it
Mar 24, 2008 | SanDisk Sansa e260 MP3 Player
"Battery Is Too Low System Shutdown"
The battery has come loose from the contacts on the inside.
Remove the back (4 screws), remove the battery and put it back in securely.
Then charge it for a couple hours.
Best of Luck.
Nov 14, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
57 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
