Question about GE Dryers
My dryer isn't getting hot. What would cause that?
  • GE Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101...
Posted on Oct 15, 2010
The dryer isn't getting hot
Here's a good troubleshooting article on them:
http://www.ehow.com/way_5389575_troubleshooting-kenmore-series-dryer.html
Keep in mind, it is an older dryer, but that series is known for being really good. If the article doesn't check out, I would suggest calling in a technician as it's possible something got damaged in the move/
Dec 31, 2012 | Kenmore Dryers
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
My dryer is turning but it isn't getting hot? What
dryer element not getting hot .possibly only 110 volts instead of the needed 220volts ...maybe a bad breaker in fuse box
Nov 29, 2011 | Kenmore Dryers
I changed the fuse and the dryer was hot at first but isn't getting hot again. What else can I do?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 15, 2011 | Dryers
My hot point dryer won't start. the turn knob isn't clicking anymore and won't wind up.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 09, 2011 | Hotpoint Dryers
Dryer will get hot but will not dry clothes
If the dryer gets hot, but not drying the clothes my first question would be if the drum is turning or not. If not then I would check the belt and make sure it isn't busted. Then I would check to make sure that your exhause hose is not clogged up. If so clean out.
But if that isn't the problem then I would check the blower assembly.
Aug 07, 2011 | Dryers
Clothes are real hot to the touch
sounds like you have a venting problem,, check for clogs or blockage in the vent pipe,, and also at the exit from the house to be sure the vent cover flows freely and isn't smashed down. check inside this vent to be sure the flap inside of it moves freely and isn't stuck,, Normally when clothes get hot to the touch its caused by the clothes heating up to dry and the moisture isn't allowed to be vented out
May 24, 2011 | Whirlpool Dryers
Dryer shuts down sometimes , sometimes gets too hot then shuts down until it cools
First thing you will want to check is the lint screen, if the lint screen is clean, check the venting system. Unhook the 4" hose behind the dryer and look into it to make sure it isn't plugged up with lint. Also, check the rest of the vent all the way to the outside of the house . If the vent is stopped up it will overheat the dryer and cause other problems down the line.
Apr 18, 2011 | Dryers
My dryer isn`t get hot. What should i do? kenmore-400. I live in Pembroke Pines. Florida
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Dec 18, 2010 | Kenmore 400 6943 Dryer
Dryer shuts off when it gets hot but restarts
1.Remove your exhaust duck on the back of the dryer and clean it.
2.Make sure your exhaust going to the outside vent isn,t clog.
3.Check thermostat.
Mar 07, 2010 | Dryers
Dryers Logo
49 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
