Question about Toshiba 26HLV66 26 in. LCD TV/DVD Combo
I have a Toshiba 26HLV66. It will not power on and the light beside "Disc" flashes three times.
3 Suggested Answers
SOURCE: won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Posted on Dec 09, 2008
walesarumi
  • 6993 Answers
SOURCE: Toshiba 46hm94 tv doesn't turn
Remove the TV wire from the wall plug, wait for about 30mins for TV to settle, plug it back into the wall and power on the TV and see if problem will persist.
If problem persist then problem is either from a dying lamp or a power problem. If the blinking light it green, then it means you need to replace the lamp, but if the blinking light still persist after changing the lamp, it means your TV is having a power problem.
This problem is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on Aug 13, 2011
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Power supply replacement for a lcd Toshiba install video
Try website like You Tube,type in LCD tv power supply replacement,should have a tutoring video by somebody doing it,the replacement.
Jun 23, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Feb 10, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
No sound at when I set SAP to English
took set 26HLV66 to service center to have tuner replaced
Feb 18, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
The 26HLV66 turns off after about an hour.
Sounds like a main board problem, basically a short if still in warranty call to have serviced if not, honestly a 26 hdtv these days would be cheaper to purchase new. wait till black friday or any time really the way the economy is is opening up great prices on hdtv technology, just my two cents
Oct 24, 2008 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
Won't come on
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Toshiba 26HLV66 26 in. LCD TV/DVD Combo Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
