Question about GE JKP86 Electric Double Oven
Both elements in oven don't heat up. - GE JKP86 Electric Double Oven
    Problem Solver:
  • 10 Answers
Have you checked the breaker box to see if a breaker has tripped? To reset it you would need to make sure it is fully off then turn back on. You can also check to make sure that the elements are not corroded and causing loss in contact. If the breaker is good and the elements are making good contact. You can check the element contacts with a multi-meter by removing one element and checking the power to the element at the back of the unit, just remember that this is a 220 volt system, so be very careful with the contacts. If there is no power registering it could be that one of the wires for the power to the elements has shorted out.
Posted on Oct 14, 2010
Help it lights up but no heat.
Dont use it! You need to pull the cooktop and see what is wrong. There is a chance that the circuit for the surface light is the only standing circuit left because the heating element is bad or loose
May 20, 2013 | Ovens
I have a Zanussi ZHQ575 X Double oven, the main oven will not work when I select the Fan Oven setting. I have tried a new selector switch but it still will not work on this setting. The fan comes on but...
I have the same problem.... It's not the element gents, please read the question again... the oven heats up on the other settings it's just when you select fan oven (the most popular) I too have tried replacing the selector switch with no luck. Really need a wiring diagram.
Apr 14, 2012 | Zanussi ZHQ575 Electric Double Oven
Electrolux E@30GS65GSD bottom oven won't heat
most likely it is a bad element easy and cheep to replace check element for burn spots on it with a flash light don't touch unless you have the power turned off , get back to me if you need a part but i will need all info on this oven
Dec 06, 2011 | Electrolux Ovens
Jenn air gas oven won't light off/heat up
Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
Jun 13, 2011 | Jenn-Air Ovens
My electrolux EOB5610 wont heat up....the fan works and the grill works but will not reach any sort of temp !!!!
Jun 02, 2011 | Electrolux EOB5610 Ultrafan Electric...
Hi i have a Samsung oven bf641fst the light and fan come on but the heat side wont work and the led sceen is blank?
May 31, 2011 | Viking VESO176 Stainless Steel Electric...
Bad ignitor? I have a Maytag oven CRG9800BAE displaying F7. No oven heat. Stovetop burners work fine. Got the code cleared, clock is working fine. Is this a bad ignitor? If so, could you confirm the...
Thanks for choosing FixYa and welcome. If you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defetive heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
May 12, 2011 | Maytag Ovens
I have a Thermodor SCD302ZP Double Convention Oven. Does the lower heating element come out from the front of oven or do you need to gain access to rear in order to test/replace it? I removed the...
that model number doesn't come up.first make sure the power is off to the machine,you have 240 volts going to that element,all the thermodor ovens i worked on come out from the front,there should be two phillips screws holding it in place,remove the screws and pull the element forwards,some of them you have to lift the element up the end that goes through the wall is bent up so the wires don't hit the metal wall behind it.on some the wires are very short so don't be surprised if they pop into the hole on you,try to hold it with a needle nose,have the other element in there and stick the wire right on the new element so you don't loose the wire into the hole,if that happens you might have to pull the oven and remove the back panel.good luck and i hope this helps you
May 11, 2011 | Ovens
Oven wont heat up, the grill does and the clock, timer works
Thanks for choosing FixYa and welcome. If you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defetive heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection. Thank you for your time and thanks for choosing FixYa.
Feb 28, 2011 | Bosch HBL 5052 Electric Double Oven
Oven's bottom heating element does not heat
this should show you how to change it
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
The main fault when the oven is not heating is that the element has blown here is a video on how to change your fan oven element and the motor.
For all your fan oven element click here
Jan 07, 2010 | Frigidaire Ovens
GE JKP86 Electric Double Oven Logo
234 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
