Question about Singer 3116 Simple
Gathering thread under the clothes
I have a singer 328k sewing machine. When i try to sew then all thread gather under the clothes. do u have any suggession?
  • atipnes Jun 22, 2008
    the thread gathers in clumps, it is in pieces on the under side of fabric. the upper side of fabric facing me seems fine, it looks like it skips a stitch here and there, so when i go to investigate, i find clumps of chopped up thread under the fabric.
    my entrire bobin case contents fell out and i wonder if i may have reinserted them wrong. im not taliking about the bobin or its case. im talking about the case that houses the bobin case. its a singer "prelude" from Target.
  • Singer Master
  • 7,365 Answers
Check needle to see if it's in backwards
check needle to see if it's bent-lay the needle on a flat surface & roll the needle over, if the needle doesn't roll good replace
check to make sure machine is threaded right
check for lint or loose thread fragment in bobbin area
Posted on Jul 30, 2010
I am trying to gather I have a gathering foot on but it isn't gathering please could you tell me what tension it should be on
Tension should not have a large affect on gathering other than one thread will lay on top of the fabric instead of both threads meeting in the middle of the fabric. There are several different kinds of gathering/ruffler feet, so it is difficult to address appropriately.
How To Use Gathering Foot
How to Use Gathering Foot 2 Ways The Sewing Rabbit
Gathering Foot VS Ruffler Foot Sewing Parts Online Everything Sewing...
Nov 06, 2017 | Sewing Machines
Stitching keeps gathering while I'm sewing
#1 cause of puckering is a tension/threading problem. Make sure the thread/needle matches the fabric type too.
Dec 14, 2012 | Singer 3116 Simple
I have the singer 7442 and i cannot figure out how to get the baste stitch for gathering material on a flower girls dress. I've tried everything and there's nothing in the manual, can you help with this?...
Normally to gather fabric, you select the regular straight stitch, turn the stitch length up to maximum (4 or 5 usually), and stitch two rows of stitches, one at 10mm from edge and one at 20mm from edge.
Then gather by pulling the bobbin threads (underneath ones) from each end to gather the fabric. If doing lengths of more than 1 metre, then stop, leave long thread tails, and start a fresh length of gathering threads to avoid gathering long lengths of thread which might break on you.
If your machine has a basting stitch it might look like " .___.___.___" on the dial however, I've never been that happy with machine basting for things like attaching slippery fabric to underlining, I've always done it with needle and thread to keep the two layers matching and not stretching/slipping. For example, stitching a piece of chiffon to a underlayer of satin, even pinning carefully, these two fabrics will slip under the machine foot so I'd always do it by hand.
If you have masses of fabric to gather, sometimes what is quicker is doing a large wide zig zag over a length of perle cotton (heavier than thread) at the 15mm seam, don't let the needle pierce the cotton though. Then you can gather the fabric along the perle cotton.
Sewing machine instruction manual often assumes a knowledge of sewing techniques that you may not yet have. I have the Vogue Book of Sewing on my shelf and refer to it often. Or Singer do a good range of sewing books too, its worth investing in a good reference book.
I also love, this is such an awesome website for dressmakers/sewing enthusiasts and you will find loads of helpful tips here.
Hope this helps you a little.
Apr 16, 2011 | Singer 7422
Singer 5050 sewing machine threads gathering under fabric and becoming knotted. how do i fix this
Try a new needle and rethreading. Check your threading by putting the presser foot up , then pull thead, should move smoothly, now put presser foot down, now pull, it should barely move. This usually seats the thread in the tension discs.
Jan 02, 2011 | Singer 5050 Mechanical Sewing Machine
SINGER CURVY: It jammed while sewing felt. Taking apart the bobbin area, I can see that the needle hits the bottom of the "floor". The bobbin is not catching or moving.
I think that your should try a new needle, it may be bent or have burr on it. It problem persists call Singer at 1-800-4singer, good luck
Sep 12, 2010 | Singer Curvy 8770 Electronic Sewing...
The bobincase springs up giving no stitch in singer inspiration
Try buying a new bobbin case, it probably was damaged by jumping out of position.
May 06, 2010 | Singer 5050 Mechanical Sewing Machine
Thread gathering in ball under fabric It is singer futura 150
sounds like a tension problem. You can call 1-800-4SINGER. The singer rep. should be able to help.
Or email at
Aug 31, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer 3116 Simple Logo
307 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
