Question about Intermatic & Indoor/Outdoor Rain Tight Timer
New 220 timer put in ,wont turn on.Vsiual chek working and its keeping time,switches look good but woont kick on?
I wish I knew the model number.
maybe the wiring is wrong, but different model numbers have different wiring.
I wrote a page on each the T-104 and T-1906 240V timers:
It shows the wiring for 2 common Intermatic timers
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/How-to-wire-T1906-Intermatic-timer.html
Now let's troubleshoot a bit:
You say the dial is rotating around.
And the dial has tripper pins in place.
What about the manual override? Does the manual override turn lights on and off?
If manual override does not turn on the Load, then your wiring is suspect.
If manual override works, then your wiring could still be wrong by one wire.
Check your tripper pins.
Are they attached and set exactly right?
Are you using both ON trippers and OFF trippers?
New 220 timer put in ,wont turn on.Vsiual chek - 1565897.jpgThe OFF tripper pushes a lever. The lever is connected to Manual override. Click manual override to see if timer can turn Load ON-and-OFF
Up-vote if this information helped. Thanks for the feedback.
Posted on Oct 15, 2010
P1353ME Intermatic Pool Timer starts and then stops
sounds like you are working with 220 2 blue are two hots across the two you should get 220 volts each of the greens and green should only give you 120 volts make sure unit can be wired 220 volts
Jul 05, 2015 | Intermatic P1353ME Timer, 3-Circuit Pool &...
I would like to replace five Intermatic wall switch timers (model WG230-6) that are not presently working.
The Intermatic E1020C timer is a 120 volt, single gang, single pole switch. This means it must ONLY be used on 120 volt circuits (to operate the internal timer motor), will fit into a standard electrical swithbox (does not require over or double sized boxes) and will replace a standard, single pole switch ie: has ONLY two terminal screws (not including the green ground terminal) and if a toggle type - has ON and OFF on the handle. The only additional requirement is that the switchbox will need hot (often black or red) & neutral (nearly always white) power in wires and hot (again, black or red) and neutral (again, nearly always white) power out (to the light or fan) wires. Many times, these devices are wired a little differently - with just 2 wires - instead of the four cited above. This is to provide power to keep the timer motor operating. The manual for this switch can be downloaded (and printed) here.
The part number of the old switch you provided does not appear to be correct. This number lends me to believe that it is for a 220-240 volt circuit. The closest I could find to an Intermatic part number was WG230-13. This part is the timer motor for replacement on a differnt style timer. It is indeed a 220 - 240 volt clock motor as I suspected. Please double check the brand and model number once more.
Lastly, if you can not find the info requested above, you should be able to replace the old timer with the new style - provided that the installation requirements cited in the first paragraph are met. Shut the power off before removing timers and switches and test with a working meter to be sure.
I hope this helps & good luck!
Nov 21, 2011 | Intermatic Hardware & Accessories
I have the Intermatic T-104. Hate to toss things out if it's just a minor problem. The timer keeps accurate time. The "on" switch doesn't work; the "off" switch does. I...
Open following link to determine if timer is bad:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Key things are clock dial rotating on timer, and manual override lever turning load ON-OFF.
If clock motor is rotating and keeping good time, then you know that timer is receiving 240Volt from circuit breaker.
Check for loose wiring, and then check if you have 240V across terminals 2 and 4.
If you have 240volt across terminals 2 and 4, then that says 240V is going to Load, and that load is suspect.
Buy cheap multimeter from hardware: set multimeter to read 240 or 250V, and put test prongs on terminals 2 and 4, and then move override lever and test again.
Safety: Tape multimeter leads to wood sticks to keep hands away from power. Stand on dry boards. Use adequate light.
If timer is genuinely bad, then you can buy timer insert: T104M
Usually it is cheaper to buy whole new T014, and then snap new mechanism into old box.
Aug 12, 2011 | Intermatic T104 24h 208-277v Mechanical...
T104 timer would not shut off, thought it was timer so bought new timer and switched out the insides - keeping wiring the same. The timer will not turn on or off any ideas.
I had a problem like this before with a similar timer.
The wires used were large 6 gauge. They were so large that it put stress on the back plate of the timer and it wouldnt work at all. I adjusted the wires and then it worked just fine.
Its one idea.
Jul 01, 2011 | Intermatic T104 24h 208-277v Mechanical...
I hook up my t104 to day the only to make it come on is to manualy turn it on by the switch check all wires it is wired rght, put meter on it has good currint to all terminals set time to come at 600pm...
Did you install the ON and OFF tripper pins on the wheels?
Are the clock wheels keeping time?
Intermatic Support can be reached at the following phone number:
815-675-7000
Gary
Dec 11, 2010 | Intermatic T10404R - Two 220 time clocks...
GE Digital Time Switch (15132) for basic landscape lighting
Leave the breaker off, remove the wires from the timer and just connect them. then turn the power on. Unless you have a short somewhere, the lights should come on. What you have just done is made the breaker your switch. If the breaker kicks you know to keep looking for a short as it is not the timer. Regards, Joe
Jan 04, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
T103 has been sticking. When the
It wont turn on as soon as it touches the pin . It has to go by it a little to flip the switch. if it goes completely by it and still wont go on, the pin may be loose or worn out. Will it go on by turning it manually?
Nov 08, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
There is no power to the controls . I just put a new belt on and when I was done hooking everthing up there is no power.
Check to make sure your breaker did not kick out...
Also check the power at the dryer plug to make sure you are getting 220 Volts.
Replacing the belt should not effect the electrical of the machine unless you pulled some wires off the timer/start switches...that is where you should check if everything else is ok.
Good Luck,
I hope this helps.
Oct 12, 2009 | Samsung Dryers
First alert timer 220
First Alert 6262 Patterson Pass Road, Suite C Livermore, CA. 94550 1.800.458.1385 orders@vwimc.com
  1. Set current time with arrow at top of dial
  2. Time on, push and slide white pin
  3. Time off, push and slide grey pin
  4. Automatic override, use red switch on side
Comments on some sites that refer to this unit is dont waste your time .. heap of junk, wasted hours and it still didnt work.
So good luck
Please rate our help to keep the FREE service online
Aug 30, 2009 | First Alert 24 Hour Timers - 2 For The...
Heat on after replacing thermal fuse. By 5-10 minute heat off
First i would cheak your breaker panel to see if your double 30 house breaker kicked out on 1 side or if you have a voltage meter cheak for power you should have 220 volts.going across on you plug box.If those are good chek your thermal cut off located on your heater housing on the top and cheak for continuity across.If good you need a element.cheak that across on tester to find out good luck:) PS If that is good you may need timer or motor
Apr 30, 2009 | Whirlpool LER4634J Electric Dryer
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
66 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
