Question about Kenmore 15864/15862 Top Load Washer
Just hooked up machine from our move. It worked properly when loaded on truck. Now, the cold water works in the warm setting but the rinse is all hot, not cold like the machine says it should be. Yes, the hot line goes to the hot valve and the cold line goes to the cold valve. Not sure what to think.
  • farmerjoe72 Oct 14, 2010
    Thanks but I tried that as well. I guess maybe one of the water inlet selenoids is bad or the wire is lose or something. I'll check that.
    thanks again.
    President:
  • 1,218 Answers
Good day,
It's possible the faucets are backwards. Before you do anything else, just reverse the hoses and try it again. Should solve your problem.
Posted on Oct 14, 2010
EW1200 is rinsing in hot water how do we change that
Hot wash, hot rinse is for 'whites'. Cold wash, cold rinse is for 'colors'. Warm wash, cold or warm rinse is for 'permanent press'. Check your settings to see if you have these options. Double check the hoses, put the machine on cold fill and feel the hoses.
Has someone worked on the machine and possibly put the wires on the solenoids wrong? Easy mistake to make.
Mar 10, 2012 | Electrolux EW1200i Front Load Washer /...
Can neighbor use washer using cold water hook-up only?
Good day,
Yes if cold wash and rinse are used only. If the selector is set to warm accidentally, water would fly out of the hot water port when filling. Be careful, or hook up another cold water supply to the hot inlet.
Nov 01, 2010 | Maytag LAT3600A Top Load Washer
Cold/cold wash uses hot water wash and warm rinse. I have t set to hot/cold wash to get cold water wash.
probably the water inlet hoses are hooked up cold water line to the hot water inlet and vice versa
Aug 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Front load kenmore washer will not fill on rinse cycle
yes you should have both hot and cold hooked up. if that is not possible splice the line you have and y it into both inlets. thats not the best way to do it but will solve the imediate problem.
Jan 24, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool washer new..,. washes cold wash cold rinse.. hot wash cold rinse.. but on warm wash is cold wash cold rinse I can send wasdher back just got it t0 day or is there something I can do?
Be sure the hot water valve is all the way opened first. Both faucets must have equal pressure for washer to work properly. They all rinse with cold water, this is normal.
Jul 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Can't get anything but warm of hot water
If you set the washer for cold wash with a cold rinse, no hot or warm should enter the machine. If any hot or warm enters machine on cold / cold, check to see if the hot and cold hoses are hooked up correctly, and not reversed.
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
No water enters on rinse cycle
I was partially wrong on my diagnosis. No cold water enters on either the wash or the rinse cycles. I also heard odd noises from the inlet valves. I realized the cold water valve was not opening. I've ordered the mixing valve and plan to replace it as soon as it comes in.
May 20, 2009 | Kenmore Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Sep 07, 2007 | LG WFT1071TP Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
29 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
