Question about Riso RZ390 Duplicator
Film is separated from ink roller. How do we fix? Master copy not printing.
  • 55 Answers
Seems that you have mismatched the sides of the master. Are you sure you placed the master correctly? An original Riso master should have a text at the side of the roll to show where the coloured flange should be.
Posted on Apr 30, 2011
Hp photosmart c3180 will not feed paper to print
Might be paper pick up roller warn out, clean or replace it.. For tech guys only: check for separation pad acting while service station performing? if not remove service station check separation pad leaver notch not in proper position in service station, position it. remove total mechanism up to pick up assm.. check pick up roller spring.. tension the spring. fix it back.. verify the print ...
Jan 09, 2012 | HP Photosmart C3180 All-In-One InkJet...
I am facing frequent tearing of fuser film code 00007.The engg. advised n converted 4570 canon to reduced speed approx 30-35 copies per min. but the problem persists after every 18000-20000 copies .Please...
if the fixing film keeps to wear down rapidly, the problem can be few things.
  1. Maybe the pressure between fixing film and silicon roller isn't good ( replace silicon roller, silicon roller bushings, and execute the nip check in service mode )
  2. Maybe that the fixing film isnt Canon and therefore lower quality.
  3. Maybe the fixing heater ( beneath the fixing roller ) has "nose" or place where the fixing film gets stucked or wraped. Change the fixing film assembly ( Canons film + heather in assy )
  4. TO BE SURE, THE BEST SOLUTION IS TO CHANGE THE WHOLE FIXING ASSY with new one.
Hope that helps!
PS for service manual you leave your e-mail...
Aug 01, 2011 | Canon imageRUNNER 4570 Copier
E000007- 0000
E007 is fixing related error! You need to change the fixing film. After replacement of fixing film, replace the cleaning roller of pressure roller.Change the cleaning roller every 10-15K copys to prevent premature fixing problems. If you have over 300 000 copys change the press.roller bushings and rubber ring , if you have over the 500 000 copys the best solution is to replace the whole fixing unit, little expensive but worthed
Feb 05, 2011 | Canon 3045 Black and White Copier
Uneven copy quality- Canon Copier
If the toner isnt burned on paper it means that you have to change fixing roller bushings and fixing roller.
Because you have uneven pressure between fixing and press roller
May 27, 2010 | Canon imageRUNNER 1023iF Black and White...
Hi,I have a brother printer DCP7200 Lazer I refill...
there is no special toner, check the connector that connect the magnetic roller to the charger and try another bottle of toner if the problem persist change the cartridge
May 19, 2010 | Brother DCP-7020 All-In-One Laser Printer
Leaking Ink Cartridge
You need a shop to clean the extra ink that's coming up on the rollers and install a mylar strip to prevent that in the future. It's the waste ink being forced up thru the exit rollers and getting on the prints.
Sep 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
After I make a master, my first copy gets stuck on the drum.
Please check the transfer / separation corona wires.
Jul 31, 2009 | Riso RZ220 Duplicator
Ink is on the back of my printed pages
open the printer and clean all rollers you find. should fix your problem if the line goes from top to bottom
Jul 20, 2009 | OKI C3200n Led Printer
Ink film wrapped round roller
Hi
Unplugged and try to access inside of the printer, be extra careful because you might damge the sensors. If its hard to get the film around. have it service instead.
Hope this helps
Nov 08, 2008 | Kodak EasyShare Thermal Photo Printer
Wide black line down middle of paper
I have same problem, with new ink cartridge, also tried cleaning the print head, no luck.
Oct 20, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Igor Studennikoff
Igor Studennikoff
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
