Question about Dryers
How do I remove an old door hinge on my creda 37761 tumble dryer and put a new one on
  • 209 Answers
SOURCE: Tumble Dryer won't start
assuming what you say you checked is correct and working then the next place to look is the start relay, located behind the front timer control panel, this sis more often than not a cubed shape box made of clear plastic with about 6 spade connectors on it, look for burn marks inside it, replace if looks damaged, do not attempt to bypass or short out to test, as you will blow the timer or and control circuit board and cause extensive damage
Posted on Sep 26, 2007
  • 189 Answers
SOURCE: WHIRLPOOL DUET DRYER
I've searched around for DIY instructions, but those are exceedingly difficult to locate. It seems that Whirlpool wants you to buy their Door Reversal Kit for 11.99 in order to accomplish this.
http://www.whirlpool.com/catalog/accessory_product.jsp?parentCategoryId=375&categoryId=376&productId=895
Posted on Jan 07, 2008
SOURCE: tumble dryer Creda Smplicity T320VW
I am an authorized servicer for Creda and I can explain how to remove the front panel to change the belt. Email me at starztruck4u@aol.com if you still need help.
Posted on May 19, 2008
  • 1462 Answers
SOURCE: creda tumble dryer repair
with great difficulty - these belts are so tight!there is a special tool for doing it but there are other ways
one way i have used is to make a spanish windlass from belt to bottom of machine. when belt is level with motor spindle, push belt on and release spanish windlass. could also try levering belt on with a screwdriver
another method is to get a short piece of tubing that will fit over motor spindle. put belt over tube, lever down and slip belt on. this is the best way
Posted on Jul 20, 2008
AlmostBob
  • 550 Answers
SOURCE: how to fit a belt
open case
loop belt around bits
close case
more particularly
Unplug dryer
pull dryer away from wall
remove 1 screw each side at back of top plate
slide top plate backwards and lift off
undo 1 screw each side of front kickplate
tlit front panel up
unplug door switch
set front panel aside
careful of control panel its V.fragile
(I lay the dryer on its back)
pull out old belt and bits of belt
loop new belt round drum at wear marks
pull tensioner to end of travel against spring
loop belt round motor pulley & both tensioner wheels(most creda) 1 wheel (old)
relax tensioner
rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
creda uses hotpoint parts
Posted on Oct 31, 2008
Creda 37761 problems drum will not turn heating up
OH OH SOUNDS LIKE BAD WINDINGS ON THE MOTOR, HAD THIS PROBLEM LAST WEEK , THE MOTOR WAS SHOT AND WOULD NOT TURN THE DRUM, I TESTED IT WITH MULTIMETER AND MANUALLY, BY OPEING UP AND TAKING BODY OFF THE DRYER, remove the drum and belt, JUMPING THE DOOR SWTICH, AND THEN STARTING THE DRYER, BINGO It the motor STARTED RUNNING, but when I put body, drum and belt back on BINGO no running or turning.
Sep 14, 2014 | Dryers
Creda simplicity dryer
new interlock then .....cheers
Jan 30, 2014 | Dryers
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
Hi the door catch for my Creda T522VA Simplicity dryer has broken - where can I get a replacement?
http://www.espares.co.uk/parts/tumble-dryers/doors/creda/t522vw/p/1580/720/0/423760
hope it helps
Jul 05, 2010 | Dryers
How to fit a belt to a creda tumble dryer
open case
close case
more particularly
Unplug dryer
tlit front panel up
unplug door switch
relax tensioner
Oct 30, 2008 | Dryers
Door Hinge replacment
my door indicator light wont stop flashing the door is locked
Mar 05, 2008 | Creda W100FW Front Load Washer
Washing machine door hinge
I cant find much on this unit. the back can be remove but will likely not help you .
remove the top access panel ,
remove the front control switch panel.
then you can remove the whole front door and all.
its really not that hard just be careful of the plastic items.
Feb 27, 2008 | Creda W100FW Front Load Washer
Dryers Logo
26 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
