Prolink 3.5G HSPA Router PWH2004 cannot connect to the internet. the wireless networking also does not work. what's the problem
watz up
  • 6 Answers
SOURCE: Thomson TG 585 v7 Wireless Problem
HI
The following info. might help you fixing the above problem:
For WIRELESS CONNECTION follow these Steps:
(Note: Keep the Ethernet cable plugged in unless we set up
WIRELESS)
1: Click on Home Network
2: Wlan
Click on Configure which is the 3rd last icon on the Top
Make sure that the option-Interface Enabled is ticked.
Channel selection should be ob Manuall.
Wireless channel can be 11( thats what is in my case).
Encryption is again depending on what type of sercurity you wants. I would suggest go for WPA.
After editing the above info. do not fail to note the KEY before clicking Apply
Now just enable the WIRELESS CONNECTION on your PC /
Laptop,
Pull the SSID of your router and Click connect.
It will ask for the WEP/WPA key?
Enter the key and Click connect.
Posted on Sep 11, 2008
Teis
  • 340 Answers
SOURCE: di-524 dlink; wireless laptop connects but no internet or network
Your wireless card is dead, replace.
Posted on Nov 23, 2008
dragoness1
  • 60 Answers
SOURCE: i cannot connect to the internet but network is working...
did you config the router as an access point?
does the internet work when you by pass the router?
Posted on Dec 22, 2008
Bat1956
  • 585 Answers
SOURCE: setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Dec 28, 2008
Rajan Solank
  • 62 Answers
SOURCE: computer and wireless router being connected but no internet
To reset the Modem all you have to do is to get a Paper Clip or any object that is like a paper clip then just turn your router to the place where the LAN cables are and just nearby you will see a small button that is abit hidden , so just press that and while pressing it for 5seconds, remove the power cable and plug it back while the clip is still being pressed in the reset button.
Remove that clip from there and you should be able to see that your power light on the router is blinking, wait till it get stable, then all you have to do is login with going to 192.168.1.1 then enter the default username and password which is either admin, admin, or root, password. or root, admin
Then just configure your router again and all shall be well.
THanks.
Hope this helped you.
Posted on May 26, 2009
How can I put password on my prolink-h6300g router
Open INTERNET EXPLORER and. (In the URL address field), enter the IP address for your wireless router ( the DEFAULT GATEWAY. This information should be contained in your router's manual. If you cannot find it, enter "198.168.1.1" as the address. This is usually the default IP address for most routers.do not type "www" just the number
Enter the username and password for your router. This should also be supplied in the router's manual. If you don't have this information, go to routerpasswords.com and find the brand and model of your router. This site lists the default login information for most wireless routers you can try "ADMIN" for user name and "PASSWORD" for passsword.
You should now be able to see your wireless router settings. You can configure your network ports, as well as SSID (wireless network name) and passwords.
Mar 29, 2011 | Computers & Internet
I just got a NETGEAR n600 dual band router, ran the resource cd to set up the network, and everything was successful. Whenever i connect to the wireless network my computer says its connected to an...
My Friend ,
Seems that the router is producing the wireless signal the problem is only with the computer.
What i can suggest you is to delete all the wireless networks from the list and then try to add the network again.
Dec 09, 2010 | NetGear WNDR3400 N600 Wireless Dual Band...
When i connect webcam cable in to usb my internet connection is g
This is a problem on some computers that "share" a usb port and don't have seperate interrupts or aren't done correctly. Try a USB splitter from computer store or walmart ($10-15.00) and that should take care of you.
Mar 28, 2009 | Compaq Presario 5000 PC Desktop
Setup linksys wrt54g2 broadband router with prolink h9200 modem
Dec 27, 2008 | Linksys Wireless-G WRT54G Router
Losing internet connection when enabling ICS on the wireless network connection
Do not enable ICS on any of the computers that are connected to a router regardless if it's wired or wireless, you only need to enable ICS is if you don't have a router/server on your network(the purpose of a router is to share a single internet connection from your ISP). To connect your computer wirelessly to the router(on a Windows XP computer given that you do not have a 3rd party Wi-fi application installed) is to right click on wireless network connection on the System Tray(lower right hand side of the computer's Desktop near where the clock is) or you can do it the hard way by going to Control Panel then Network Connections and choose view available wireless network and under the list of available network that your computer can detect, select the network name(also called SSID) of your wireless router and try to connect(of course if you enabled Wi-fi security you also need to key-in the security key(WEP/WPA) you configured on your router and that's it both wired and wireless computer/devices connected to the router should work at the same time.
Nov 05, 2008 | Belkin (F5D7230-4) Router (587009)
Wireless router, laptop problems
Try to delete all the prefered networks. Right-Click Wireless Network Connection, View Available Wireless Networks. Click on Change the Order of Prefered Networks. Remove all prefered networks there and click OK. Now try to View the available wireless networks again, reconnect to your own wireless network and see if it connects fine. Post your feedback.
Jul 12, 2008 | Linksys Wireless-G WRT54G Router
I can't go online
my problem is related to data acquisition from a data recorder like CVR to laptop using wireless techniques. what are the devices supposes to use? it should compliant to 802.11 b/g/n.
Jul 09, 2008 | Prolink Computers & Internet
Cannot connect to router wirelessly.
Yes that's it.. try changing some wireless settings on your router like the ssid or wireless network name channel use channel 1, 6 or 11 then try to connect to your wireless network.
May 09, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Iam not able to connect to internet via wireless router
Need more information to help you.
1. If not using the router at all is there connection to the internet??
2. When working woth a utp cable between computer an router is there internet connection??
Don't forgett getting connection with your wireless network is not the same as gettin connected with the internet.
Suggestion: Clone your computer MAC address in the router.
Jan 23, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
551 people viewed this question
David Payne
David Payne
