Question about Dacor Millennia ETT365 Electric Cooktop
The center large burner keeps shutting off after being on for only a few minutes.
    Problem Solver:
  • 87 Answers
Ur element is cracked
Posted on Oct 14, 2010
NEED TO REMOVE RANGE TOP. THE LARGEST BURNER NUT HOLDING THE VENTURI IS STUCK. OTHER THREE BURNERS REMOVED OK. DO I HAVE TO SPLIT THE VENTURI NUT TO REMOVE RANGE TOP? I NEED TO GET INSIDE RANGE UNIT.
Yes keep playing with it and BOOOOM! Call in a professional. This is the law with gas appliances.
And turn off the CAPS lock. We heard you the first time :-)
Jan 24, 2016 | DCS "CTD-304-L 30"" Drop - in Cooktop, 4...
I have bosch pgl985uc burner problem. The center burner will not stay lit.
I have the same problem especially with the center burner, but now am having increasing difficulty with two other burners. Those will eventually stay lit if I depress the knob for 20 - 30 seconds. The center burner will not stay lit, even when keeping the knob depressed for 2 - 3 minutes!
Mar 19, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
Large burner elements ignite, and igniter spark fails to stop, then the burner shuts off as if ignition failed. Tiny central burner element does NOT light at any time. Apparently the safety cutoff...
There is a thermistor that must be in the flame area that needs to get hot. When hot it will turn the igniter off and keep the flame on. Check it's location and if it is in the flame then it needs to be replaced. not sure about the central flame problem. could be the switch.
Sep 20, 2010 | Gaggenau 36 in. KG 291 Dual (Electric &...
Burner shuts itself off after 10 0r s minutes of working normally
this unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
Jul 12, 2010 | Thermador PC366BS Stainless Steel Gas...
Large electric burner will not turn on
you need to check the wiring to that burner it appears that there has been a short to the burner
Apr 04, 2010 | Jenn-Air 35 in. JEC9536ADS Electric...
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
When the large burner is on, it keeps trying to ignite
Check that the burner orifice nozzle (the round thing that comes off) is properly seated on the burner manifold. Mine have a tab that must interlock.
Make sure all your burner orifices are CLEAN. Scrub them with a plastic kitchen scrubber, soap and water.
The way this works is, when a burner is turned on, the sensing mechanism for the spark control reads the ionization of the flame. No flame, no ionization, keep sparking so gas buildup is minimal in the area before a flame is ignited. )Kinda like the spark thingy's underneath the shuttle, without the ionization sensor's, just before it launches.).
Jan 14, 2009 | Dacor 36 in. EG366SCHLP Gas Cooktop
Jenn-Air Expressions cvgx2423b manual request
I have the same model with the same problem. The replacement is simple. Remove the burner cap (no tools needed) Take a large crescent wrench and remove the large center nut holding the burner assembly in place. The ignitor will slide out of the assembly once it is removed. Good luck
Aug 14, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
GE Stove
check all holes on burner make sure all air/gas holes are unclogged do not use any ajax or any cleanser that will leave a powdery residue.
Nov 30, 2007 | Cooktops
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
Dacor Millennia ETT365 Electric Cooktop Logo
126 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Mike
Mike
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
