Question about Toshiba e-Studio 350 Copier
Error cdfo what is it e-studio 455 - Toshiba e-Studio 350 Copier
  • Toshiba Master
  • 643 Answers
CDF0 indicates Initialize error of the offeset tray.
Check the connectors of the offset gate motor, MOT2,
Posted on Oct 24, 2010
Error code c270 in e studio 455 still pending any one to help me
That error is related to the scanner not being in the right position (home) when it starts. This could be because the scanner is jammed, is not reaching the home position or the sensor for the home position is bad.
Jan 12, 2016 | Toshiba E-Studio 455 Digital Copier
Error code C440
Toshiba eStudio 355/455 Full Service Manual - Tradebit.com
https://www.tradebit.com/.../155135538-toshiba-estudio-355-455-full-se...
Download Toshiba eStudio 355/455 Full Service Manual ... Configuring DepartmentCodes Configuring ... TSB-1013: C440 Error - Countermeasure .... DIG-ACC-145: MJ-1025 Bracket Change to Enable Installation on e-STUDIO205L/255/305
Aug 08, 2015 | Toshiba E-Studio 305 Digital Copier
Toshiba model 455 error code CDF0
CDF0 is offset tray error on the exit unit, mostly due to the offset motor problem
Mar 05, 2014 | Toshiba e-Studio 350 Copier
Error toshiba e720 c370
Segun El Ribbon de toshiba me dice que la tarjeta de SyS es igual de la toshiba E-455 a la de la E-855. El problema es como hago la transformacion de version 455 a 855 . Mi pregunta es como hago o cual es el procedimiento . Gracias
Feb 12, 2014 | Toshiba E-STUDIO 850 Copier
How to reset cdfo error toshiba estudio 355se
CDF0 Offset tray related
service call
Initialization error of the offset tray: The home position of
the separator cannot be detected when the power is
turned ON.
[CDF0] Initialize error of the offset tray (e-STUDIO205L/255/305)
(1) Check if each connector between the OCT motor and OCT board (CN261) is disconnected.
(2) Check if each connector between the OCT board (CN261) and LGC board (CN302) is
disconnected.
(3) Check if each connector pin is removed or the harness is broken.
(4) Check if any conductor pattern on the OCT board and LGC board is short circuited or open
circuited.
(5) Replace the OCT motor.
(6) Replace the OCT board.
(7) Replace the LGC board.
Oct 31, 2013 | Toshiba e-Studio 350 Copier
How can instal toshiba e-studio 455 SE to windows 8 operating system
Jan 23, 2013 | Toshiba e-Studio 455SE Copier
Error c410 toshiba estudio 455
Check if the center, side and edge thermistors are in contact with the surface of the fuser roller
properly?
Check if the heater is broken
then do this steps :
(1) Turn ON the power while [0] and [8] are pressed simultaneously.
(2) Key in "400", then press [START].
(3) Change the current status counter value "1" or "2" to "0", then press [ENTER] or [INTERRUPT]
(to cancel [C410]).
(4) Turn the power OFF and then back ON
Jan 03, 2012 | Toshiba e-studio 455 Copier
Toshiba e-Studio 350 Copier Logo
1,111 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
