Question about Husqvarna Viking 1
The bobbin on my Husqvarna sewing machine (Viking 100) is stuck on the bobbon winder
    New Friend:
  • 194 Answers
If your bobbin still has thread on it, remove it by hand and then try to pull the bobbin off the winder.
Posted on Oct 15, 2010
    New Friend:
Http://youtu.be/mQae5jtCfbc Watch this video and you shouldn't have this problem again. You probably threaded it incorrectly. I did this last night and found that I should have left the thread to run under the presser foot whilst raised and then wound onto the spool via the metal guide on the top of the machine then it wouldn't have been incorrectly tensioned. Watch the video it explains how to do every function on your machine really nice and clearly.
Posted on May 28, 2014
Husqvarna viking 300 sewing machine bobbin winder will not stop spinning. machine will not sew when foot pedal depressed. bobbin winder just keeps spinning.
The bobbin winder moves a plate next to the handwheel that disengages the needle from moving If you can't push it back to the left you will have to take the machine apart to fix it.
Jun 10, 2017 | Husqvarna Sewing Machines
I have a huskystar E20, husqvarna viking sewing machine. I the bobbin winder is not engaging...any suggestions
To answer the posting of: " By cakes_bynich on Mar 20, 2011
I have a huskystar E20, husqvarna viking sewing machine. I the bobbin winder is not engaging...any suggestions" Are you using the right bobbin - class 15 and not 15J? I am having a similar problem and I believe it's because I'm using a bobbin 15J and not the 15. 15J's are just slightly less tall when lying flat next to a 15, and the edges of the 15J are slightly curved inward toward the thread whereas the 15's edge are completely straight and flat. If I hold a 15J just right on the winder, I can get it to engage sometimes. That slight size difference must be the cause. I'm off to pick up some new 15's and will test it out!
Mar 20, 2011 | Husqvarna Husky 145
I have a Viking Husqvarna and it seems that the bobbin winder won't disengage. when you press the pedal down the needle doesn't move but you can hear the bobbin spinning but when you put a bobbin on the...
If the winder is not moving either there is a worn part on the winder rubber, or, the winder iteself may have seized up becuae a lot of people do not realise that the spindle has to be oiled because of its high speed.
Nov 05, 2009 | Husqvarna Viking 1
Can't put a bobbin on the winder Husqvana Viking 6020
Is this a Designer 1 or a #1? There is no moving lever on the pin of a Deigner 1,they are fixed. If it's a #1, use sewing machine oil or Triflow. NEVER use 3 in 1 oil. It will gum up and cause problems later on.
Aug 31, 2009 | Husqvarna Viking 1
Viking sewing machine 545 bobbin stuck on rewind
It should just pull off of the winder shaft. There is a small spring that sticks out from the shaft to hold the bobbin in place (at least on my wife's Viking which is a different model number than yours). Is there a release button somewhere near?
Jul 17, 2009 | Singer CE-100 Futura Computerized Sewing...
Viking Husqvarna #1 + - A bobbin was stuck on the winder and I pulled it off. The black metal clip broke and came flying off. Now the machine thinks it has a bobbin on the winder and won't move the sewing...
The black plastic ring must be put back on with it oriented correctly. It can be a bit tricky, but experiment different ways.
Another small part may have come off too. If you can't get it, a Viking tech can do it for you without much trouble.
Jul 10, 2009 | Husqvarna Viking 1
Can't get machine to pull up bobbin thread
This is a hook/needle timing issue. It will need to be adjusted by an authorized Husqvarna Viking dealer or they can send to Husqvarna Viking (SVP) Technical Service Dept in Tennessee for them to do the repair. A list of authorized dealers is available at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Apr 17, 2009 | Husqvarna Viking 1
Bobbin Winder won't release
i have a husqvarna rose, i has the same problem when i started using my machine. i was suggested to not wind the bobbin so fast. the reason it gets stuck is because the thread is so tight on the bobbin it actually makes the bobbin a tiny bit smaller, making it hard to get off again. if you dont wind it so fast, it doesn't get so tight.
kylee
Mar 14, 2008 | Husqvarna Viking 1
Bobbin winder is only thing that works
What model are you talking about? For my older Husqvarna machine you had to pull the bobbin winding bit out to wind the bobbin, then push it back in when you were done.
Dec 02, 2007 | Husqvarna Viking 1
Sewing Machines Logo
455 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
