Question about Motorola AUX4100 2-Way Radio
Resetting password gm338 radios - Motorola AUX4100 2-Way Radio
Where can i find the frequency of motorola gm338
This is a business band 2 way radio and you would have to connect it to the programming software and read it or use a frquency counter
Jul 31, 2014 | Universal Motorola GM338 Rapid Six-Bay...
What is the difference between GM338 and PRO7100
GM338 is an Asia/Pacific model. Available Lowband, VHF, UHF, in 1-25 or 25-45 watts.
PRO7100 is a Latin American model. Can program in English, Spanish, French and Portuguese. Available in 200 MHz, VHF, UHF, 700 MHz.
These are very similar to the CDM1250 mobile for use in the United States. The PRO7100 and GM338 are not type accepted for use in the United States.
Feb 10, 2014 | Radio Communications
Motorola GM338 error code
Motorola GM338 with an error code, that isn't enough info to even start to solve it.
The more info you give us, the sooner we will try to resolve your issue, what are you doing to make the error code show up.
Do you know if the radio is programmed with frequencies, do you have the user manuals?????, and the more info you give the easier it is for us to find the remedy.
please repost your query with the required info and we'll get to working out a solution.
Cheers,
Peter
Jul 20, 2012 | Motorola Radio Communications
In motorola gm338 vhf radio, if programme rx.160.500 mhz exceeds there is a message display on radio monitor 'SYNTH UNLOCK' and there is a sound generates nonstop beep. what is the problem? how it rectify?
GENERAL SPECIFICATION Low Band (GM338 only) = 29.7-36MHz / 36-42MHz / 42-50MHz
UHF
403-470MHz
450-527MHz (1-25W)
450-520MHz (25-40W)
VHF
136-174MHz
So if you do 160-500 it will not generates the LOW BAND capacity because the Channel Spacing = 12.5/20/30kHz 12.5/20/25 kHz.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 24, 2010 | Motorola Computers & Internet
Passwords
take it to the service center they must have data recovery software,
or download software from
www.katz.cd
www.katzforums.com
Feb 02, 2010 | Radio Communications
What's the range of GM338 motorola base radio?
i have a similar set and i get abot 20 maybe on good days 22 miles hope that helps
Jul 21, 2009 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
Troubleshooting gm338
I have problem with my Motorola GM 338, if low out put (16w) may I ask you for the solution...
thanks a lot
Apr 17, 2008 | Radio Communications
Service manual
This radio is exactly the same for CDM1550 and PRO5100 please let me know your email to send you where you can download it.
Feb 11, 2008 | Radio Communications
Service manual for gm338
http://www.motorola.com/governmentandenterprise/contentdir/zh_CN/Files/ProductInformation/GM338_Aus.pdf
Feb 11, 2008 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
Radio Communications Logo
758 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
