Question about Frigidaire Refrigerators
The ice maker has quit and the condensor coils have frozen up
    Guru:
  • 1,524 Answers
I think you mean the evaporator coils have frozen. When this happens the temperature rises above 12* F recommended for the ice maker to work.
Posted on Oct 14, 2010
Subzero 501F icemaker slow in making ice
More thatn likely, being thats an older model, you are low on freom and the temperature isn't cold enough for the icemaker to keep constant production up. You maybe thinking the freezer is fine because stuff is frozen in there but that is why most people don't catch the problem until they lose all their food. The temperature for the icemaker to even come on is 10 degrees F. The sub zero freezer temperature should be around 0. Check your settings and make sure they are turned down but I would get a thermometer and put in the freezer and check to see what it says. If its above 5 degrees F check your condensor coils to make sure they are clean and also see it the condensor fan is running. If dirty, clean the coils and see if the temperature drops, if not call a service company.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 03, 2012 | Frigidaire Refrigerators
Water keep running no ice only making 12 to 15 cubes of ice,
dirty condensor coil, condensor fan motor not working, low on freon,taking in new water during the freeze cycle due to float or unlevel machine.
Sep 24, 2011 | Ice-O-Matic ICEU220HA Undercounter Ice...
The ice maker backed up and put extra ice on the back of the freezer causing ice tray to stick out and freezer did not close. Pulled extra ice out and closed freezer but freezer is working (2-3 days the...
Hi and wlecome to FixYa, I am Kelly. You really have 2 problems.... 1 the inlet water valve has failed causing the water in the ice tray. The only remedy for this is to replace the inlet water valve. If you can squeeze the rubber fill tube at the back of the icemaker and it is / was frozen solid the inlet water valve is for sure bad.
Turn off the water supply to the ice maker until the water valve is replaced or the current problems you have WILL repeat.
The other problem you have is due to the door being open the evaporator coils iced up big time and the normal defrosting process is not removing all of the ice. Unplug the unit and direct a fan into the freezer compartment for just over 2 hours with the freezer contents removed. While the unit is manually defrosting... open the back of the unit by removing the lower fiberboard cover and clean the condensor coils and fan along with the drip pan / tray.
After 2 hours clean up the water mess and return the unit to normal service. It should work just fine.
Thanks for choosing FixYa,
Kelly
May 25, 2011 | Kenmore Top Freezer Refrigerator
The ice maker in my Whirlpool Gold refrigerator has stopped making ice. There is ice in the tray, but it won't empty itself.
If the " tray " you are refering to , is the ice maker mold , then clean the coils in the front , under the refrig ( condensor coils ) . Also check the fan behind the refrig , to make sure it is working . An ice maker has to be 5 degrees to cycle . Bothe the coils and the fan , have to be checked to be sure the freezer is at the correct temp for the ice maker to opperate properly . If both are ok , then replace the ice maker .
Sep 23, 2010 | Whirlpool Refrigerators
The freezer side is not keeping food frozen. Every three minutes I hear something turn on and it runs for about xx seconds. The model number is ASD2626HES. The refrigerator side seems fine.
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
Hope this solved the problem, Take care....
Sep 19, 2010 | Amana ASD2626HE Stainless Steel Side by...
U-line combo not making ice. Have cleaned
bad water valve, thermostat, freezer not cold enough, make sure the ice maker metal rod is at down position or on back of the ice maker plastic water line is frozen. also depends what year combo you have, there operation is a little different.
Nov 15, 2009 | U-Line Refrigerator Ice Maker
Ice maKer is not getting water but the water side works.
Your refrig water valve , has 2 coils on one valve . One is for the water dispensor , and one is for the ice maker . So even if you get water thru the dispensor , the other coil ( for the ice maker ) could be bad . The fill tube from inside the freezer to the ice maker , could be frozen solid , keeping the water from entering the ice maker . This frozen tube , would be caused be the water valve " seeping " , which means , it isn't closing completely , and drips freezing inside the tube . indicating a bad water valve . Pour about 2/3 cup of water into the ice maker . If it dumps , but doesn't refill with water , replace the water valve but also check this tube . If the ice maker does not dump the frozen cubes , replace the ice maker , but also check the coils under the refrig , for dust , lint , etc , needing to be cleaned off . The ice maker needs to be 5 degrees to operate , and dirty coils can keep the freezer at 6 degrees or above .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Samsung 215LASH ice maker
Hi
Some reasons that also will affect the ice maker.
Defrost Problem
Modern refrigerators are designed to self defrost and it is essential to the airflow to have an evaporator coil that is clear for air movement. If the rear interior panel of the freezer has frost appearing, it is most likely a defrost problem and must be corrected before temperatures can be restored to normal.
Dirty condensor Coil
Check the condensor coils for lint and restrictions. It is located underneath the refrigerator and accessible from the rear. A dirty condensor coil will result in poor cooling, especially in the freezer.
Faulty Condensor Fan Motor
The condensor fan motor is found under the refrigerator near the compressor. This motor is essential to proper cooling. If the fan motor is not running, there will not be proper heat removal from the condensor and the result will be higher than normal temperatures in the freezer and usually in the fresh food section. Ensure the fan motor is running when the compressor is on.
Low Refrigerant Charge
If the unit has a low refrigerant change, the freezer will not reach proper temperatures.
Also please check the fill line if thats also frozen.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Apr 17, 2009 | Samsung RB215LASH
Ice maker works but no water comes out from the ice maker coil
The solenoid valve that supplies water to the ice maker is leaking,so the water get frozen and when the ice maker call for water it doesnt get through,you need to replace that solenid valve.
Apr 07, 2009 | Whirlpool ED5VHGXM Side by Side...
Refrigerators Logo
51 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
