Question about Transcend (589307) Media
Problem with disk units with Jetflash 220
Good morning,
when I connect the Pendrive he/she needs to have two serial units (I, J / F, G, etc) in the event of not finding them it doesn't work me the pendrive. I can indicate him somehow that they don't have to be two serial units.
Thank you and sorry for my not well English one.
When i cnnect the pendrive he/she tell me to format when i open the pendrive and when i formate it does to format it.
thanks you and plase solve my problem
Posted on Aug 23, 2008
Transcend 16 gb pendrive is not recognised
Right-click on COMPUTER. Select PROPERTIES, Go to DEVICE MANAGER. Under UNIVERSAL SERIAL BUS CONTROLLERS, check all the USB ports to see if they are working properly. If the USB PORT in which you have inserted your pen-drive, is showing an error, right-click over it and select PROPERTIES and make a TROUBLESHOOT.
If this troubleshooting doesn't help you, use another computer to check if your Pen-drive is working there. If the problem persists, go to the manufacturer's service center and ask for a replacement or repair.
Hope this helps, Mrityunjay.
Jun 25, 2012 | Electronics - Others
2000 excursion turn signal operates normally until you step on brake then all flash fast and weak. running board ligts also flash with turn signal. 4 way flasher lights also fast and weak.
The earth connection to the light units is poor, probably due to a corroded screw on an earth wire between the light unit and the vehicle chassis or even a corroded nut and washer, holding the light unit onto the chassis. When this happens, the bulbs being illuminated try to draw their earth connection through the other bulbs in the unit, causing them to illuminate as power is drawn through them.
Remove the nuts that hold the light unit to the chassis and use a wire brush to clean the nuts, screws and area of the chassis where they touch and reassemble. This should cure your problem. In the event that this doesn't work, find a place on the chassis nearby where you can attach a new well connected earth wire and then attach the other end to the metal body of the light unit. You MAY have to find where the earth for the light unit is currently placed and connect directly to that depending on how the particular light unit is connected and wired.
Aug 23, 2011 | 2002 Ford Excursion
When i use the turn signal both rear turn signal lights activate, and at same time when i break the turn signals stay on in the and do not blink. Not sure what is going on
Aug 23, 2011 | Ford F-150 Cars & Trucks
I need to reattach two deep cycle batteries to my fleetwood rv. Do I attach to one battery ms then attach the extra leads to the other battery , or do I attach the positive lead to one battery and the...
It should be positive to positive, negative to negative - parallel, not serial.
The simple way to tell is by how many cables you have. If you've got one positive and one negative, and only one jumper, it's a 24 volt system and should be connected in serial. If you've got one positive and one negative and two jumpers, it's a 12 volt system, and should be connected parallel.
If in doubt, connect up in parallel and test things. If everything works, it's a 12 volt system and you're good to go. If everything doesn't work (lights are dim, inverter doesn't give AC, etc.), it's a 24 volt system and you need to change to serial.
Serial - positive to system connection on battery 1, negative on battery 1 to positive on battery 2, negative on battery 2 to system negative.
Parallel - positive on battery 1 connects to positive on battery 2 and the system positive, negative on battery 1 connects to negative on battery 2 and the system negative.
Jul 06, 2011 | GPS
Need radio code for a 2003 Honda serial numbers areU1110 L9512
The battery was disconnected from my vehicle and now my radio display is flashing "CODE" and the radio doesn't work. Where can I find my radio code? If an audio unit with theft protection is disconnected from electrical power, you must enter a unique code into the unit or it will not work. This code and the audio unit's serial number are listed on the anti-theft ID card that comes with the vehicle. If this card is lost, you must obtain the audio unit serial number in order to get the radio code. Once you have the audio unit serial number, you can go to the Radio & Navigation System Micro-site to retrieve your radio code. Some newer vehicles allow you to retrieve the audio unit serial number electronically from the radio. Refer to your owner's manual for the specific procedure. Most older vehicles (model year 2003 and older) require a visit to the dealer in order to retrieve the audio unit serial number. If dealer assistance is required to retrieve your serial number, the dealer will be able to provide the radio code as well. They do charge a fortune for this service BUT>>>>.... this website is so much cheaper to obtain along with detailed instructions http://www.radio-code.com/?gclid=CMr1lJPqn6kCFU5qKgodUDlDxA
Jun 05, 2011 | Honda Accord Cars & Trucks
When my pendrive insert in my computer then a massage comes out you need to fromet the disc in drive j before you can use it do you want to fromet it nwhen i press quck formet then amassage comes out...
do you hav anything else running on your computer at the time you are trying to format this pendrive
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have a virus also select users you will see who is using your computer
stop any activity that is happening
another way to find out what the error is
go into control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might be able to uninstall then reinstall some of these files/software
hope this helps
Jan 30, 2011 | Computers & Internet
Hi After installing windows xp i have connected my pendrive to system. But the system did not detect it. When i restart the system with the pendrive which is already connected the system detected the...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Jan 20, 2011 | Gigabyte GA-G31M-ES2L Motherboard
Recognized my 4gb transcend pendrive
Try windows repair, it should fix the problem.Else connect the pendrive and check the port settings.You can check for the port settings by
right click on "my computer"-->properties-->hardware-->device manager
A new window opens and at the bottom probably you'll find "Universal Serial Bus controller". Expand that option and check whether all the ports are enabled.If the pendrive is still not detected, then the problem is with the port.Check the same with the other available ports.Any further doubts add comments.Would be glad to answer.Good luck.
Jan 21, 2009 | Transcend (589307) Media
Transcend (589307) Media Logo
468 people viewed this question
Top Transcend Electronics - Others Experts
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
