Question about Microsoft Windows XP Professional for PC
File missing while loding window xp. is there anyway without formating C:Drive?
  • 506 Answers
Use Windows XP CD to boot the system and choose the repair Option.
Posted on Oct 14, 2010
Testimonial: "Yeah. Good Suggestion. Thanks now know more thing about repair"
  • Microsoft Master
  • 11,800 Answers
Yes, perform a Repair install.
Testimonial: "Thanks."
IL.COMRES.SIR, PLEASE TELL ME HOW TO ADD(INSTALL) THE MISSING FILES OF OPERATING SYSTEM (XP/SP2)TO RUN WINDOWS PROPERLY,WITHOUT FORMATTING CONCERN DRIVE.PLS PROVIDE THE PROPER PROCEDER. THANK YOU.
hi,
1. Some hardware malfunction also leds to show msg of missing or corrupt windows file. So, try to remove any new hardware fixed and give a restart.
or
2. Try to upgrade the XP through the XPinstallation CD. If it is not possible then Reboot the system by formating the C:\ drive.
or
3. A problem in hard disk could be the reason. Better change it.
enjoy.
Apr 26, 2011 | Computers & Internet
RES.SIR, PLEASE TELL ME HOW TO ADD(INSTALL) THE MISSING FILES OF OPERATING SYSTEM TO RUN WINDOWS PROPERLY,WITHOUT FORMATTING CONCERN DRIVE.PLS PROVIDE THE PROPER PROCEDER. THANK YOU.
Hi
Use the OPERATING SYSTEM CD/DVD to run the REPAIR MODE.
REPAIRING THE OPERATING SYSTEM just load or install corrupted or missing files from your operating system thus will not delete any of your files from your computer.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 23, 2011 | Computers & Internet
When i try to lode windows xp it will not copy all files
1.check the CD if its not scratched
2. format c drive with (not quick ) option means slowly format the drive in setup
i hope t solves your problem
Apr 05, 2011 | Toshiba Satellite 1135-S125 Notebook
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
File missing. Cannot load OS. Is tehre anyway run windows again without formating?
hi dhiraj ,
if the OS OEM is corrupt options for u will be-
1. Download the dics from other pc & burn the disc in a bootable format & use it .The link to download is- http://thepiratebay.org/torrent/4418117/Windows_XP_Home_SP3_-_Bootable_ISO
2 .Buy the other copy
I recommend u to download the OS as its cost efficient& fully functional
Not much can be done if the disc is corrupt .
Oct 14, 2010 | Microsoft Windows XP Professional SP3 Full...
Os booting problem
Try running the repair console from the CD.. fixboot, Fixmbr, And chkdsk /p may repair the missing or corrupt file other wise you can replace/install the missing file with another good working system and put the drive in an external enclosure.
Jul 27, 2008 | Microsoft Windows XP Professional for PC
HP NC6000 system recovery
you have to get the cd.and please note you install the xp home first than xp pro
Apr 21, 2008 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
NTLDR missing
Without a windows xp cd you are left with only 1 option. If you have a different machine which is connected to Internet or has windows xp installed, you can download the boot files from the net or copy the boot files located on the root of C drive (ntldr, boot.ini) onto a pen / floppy drive. then change the boot order in the bios to boot from the pen drive. It should work if you have the similar partioning scheme of the source computer. If booting is successful, u can copy those boot files to your computer's C drive.
Let me know what happens.
Apr 15, 2008 | HP Pavilion dv6000z Notebook
Gigabyte motherboard cd
You do not not need your motherboard CD to preform a format on your drive. Any windows CD. Win XP home, XP Pro, Win 2000 will format your hard drive. You can also use the hard drive's Mfg's utility disks & creat a bootable floppy disk or creat a bootable CDROM disk that will not only allow you to format the hard drive but also fun testing on the drive. You can even pick your cluster size & FAT file. Write down the name of your drive & model no#. Go to the Mfg's web site & download the utility software. Chances are Windows will have most of your boards drivers in it's data base. All you'll need to do is download from Gigabyte your missing drivers. You'll need you complete model no# & version no# if you can find it.
Mar 12, 2008 | Intel Motherboard
Wnidows XP Media Center Edition 2005 search companion
Try Scanning your Computer For Computer Viruses.
then re-install Windows XP.
Your files will remain intact, if you select to leave the hard-drive As it is ( rather Than Format it ) or setup on a different Partition.
Backup your Valuable Docs/Files First.
Windows re-installation will replace any Missing-deleted Corrupt Files.
hope This Helps you.
Mike @ compurepair.
Posted @ 14.28 PM. ( G.M.T )
Mar 03, 2008 | Microsoft Windows Xp Home Edition Sp2...
Microsoft Windows XP Professional for PC Logo
97 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
