Question about Frigidaire Ovens
When I turn on the bake button on my frigidaire gas oven and then set the temp I hear a click but the oven does not lite.
  • 4 more comments
  • dlmmgr Oct 14, 2010
    Model FGB24T3EBC it has an ignitor
    Could this be a bad control panel?
    Model is FGB24T3EBC and it has a iginitor.
    This model says that it does not have a thermocouple. What other causes could it be? The click sound is coming from the control box.
    This model does not have a thermocouple. The click sound is coming from the control panel. What else could it be.
  • dlmmgr Oct 15, 2010
    I have a bake igniter and a broil igniter. If one is out will the other one work? Because neither of mine will ignite. How do I tell which is bad?
  • Frigidaire Master
  • 3,247 Answers
Unfortunately I am unable to see the suggestions provided by other fixya consultants so far.
If both the sections are not igniting then it is likely the control circuit that is failing. The relay providing trigger to the ignitor may have frozen.
Check this diagram for all the parts.
You will have to get a techician to fix it if you do not have license to work on gas appliances (in case the controller turns out to be ok).
HOpe this helps. cmmiuser01
Posted on Oct 15, 2010
  • Frigidaire Master
  • 43,501 Answers
The ignitor is bad on your oven...
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
  • 17,970 Answers
The model number doesn't pull up can you double check the number off the unit itself.
Does this unit have an ignitor? or pilot light?
It has an ignitor check it for continuity. If the oven isn't lighting that may be your problem.
Keep us updated.
Posted on Oct 14, 2010
  • ZJ Limited
    ZJ Limited Oct 14, 2010
    If it has a thermocouple, they do go bad. In case you are not familiar
    with that, a thermocouple is a safety device that makes sure the fire is
    lit before it allows the gas to flow out of the valve freely.
    The
    thermocouple has a cylindrical part that is held in the flame and then
    has a wire that runs back to the valve. They can be purchased at almost
    any hardware store or appliance parts store.
Gas oven will not lite!
look to see if you see a glow coming from the oven when you set bake. if you see a glow that meens your ignitor is more then likly bad, it is not glowing hot enough to open your gas valve
May 12, 2011 | Frigidaire Ovens
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
How do you operate oven
You should have a bake and broil button and arrows to adjust temp up and down. Of course a start button should be there. If no off button, then there should be a cancel button to turn it off. The door only locks in self clean mode.
May 21, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My kenmore gas oven won't heat. I turn to dial to temp i want can smell gas building up in oven and can see a glow in bottom of oven but will not ignite. Sometimes if I turn on a cooking eye I can then...
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
Oct 22, 2009 | Whirlpool SB160PEE Gas Single Oven
Oven heating issues.
bake ignitor is coming on but it will be weak. about $70 for part
Aug 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
OVEN WILL NOT COME UP TO TEMPERATURE
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Thanks
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Apr 11, 2008 | Ovens
Ovens Logo
65 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
