HP LaserJet 1320 Printer Logo
Posted on Jun 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Catridge i need the contact number where the catridge is availablefor 1320hp laser jet printer
  • Anonymous May 11, 2010
    you can purchase toners online.
    you can find those online almost anywhere.
Anonymous
Level 2:
  • Expert 43 Answers
  • Posted on Jun 19, 2008
Anonymous
Expert
Level 2:
Answers
43
Questions
0
Helped
44502
Points
109
The printer shows "NO catridge"
The cartridge may need to be reseated, or the contacts may need to be cleaned. Sometimes, cartridges can burn out and must be replaced. Try installing a new cartridge, don't use a refilled or refurbished cartridge as they have a high failure rate.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1helpful
"No Catridge found "is the
hi good day,try to replaced the toner or maybe the contact of toner may have a problem
OUR PRINTER MODEL NO IS HP LASER JET 3055 PROBLEM IS WHEN WE TAKE XEROX COPY OR PRINT COPY ONE SIDE PAPER COMING BLACK SHED TYPE
Firs check toner catridge or else problem with the theflon sheet in the fuser unit need to replace it.
2answers
Does this printer need a toner and a ink cartidge
If it is an ink jet printer it only takes ink cartridges, toner cartridges are for laser printers.
Printing with a faded line down the document. does it just need a new cartridge/ Thanks Nick
Yes a new catridge can be the first option for the option for the fault but if after the new catridge is put in the fault is remaining then do a head cleaning before we can think of the laser jet.
Hi, how do I unjam stuck paper? I need specific instructions...I am mechanically challenged...that's putting it lightly...
If it is a laser jet printer, first remove the Catridge, and then remove the papers present in it. Pull it out slowly else it may tear and it may leave residue.
If it is a Deskjet printer, remove the paper from the pulling side, by swithing of the printer.
I can't replace the ink because I don't know where the cartridges are located on the printer.
if you lift the top cover of the printer you can find the catridge coming by itself and stops at the center of the release area, so that you can remove the cateridge easily, but tell you are having inkjet or laser jet in laser jet the toner(catridge) will be in the front side if you pull that cover out you can get the toner outside
2answers
Where can i find the fuse of catridge for Samsung ML 1640 laser printer in India?
Hi, the cartridge that came with your printer is a demo cartridge it has no chip or fuse on it, once this is finished normally you buy a cartridge with chip, but this is expensive, we just got a chip for this model, it will work on ML-1640, ML1641, ML-2240, ML-2241, ML-2242 Y ML-2245 this chip goes on the printer mainboard, it's a permanent one, never needs replacement , it will allow you to recharge the original demo cartridege , over ondo over again, if you need more info you can contact ma at [email protected], thank you..
k24674
Grand Canyon Tech
Grand Canyon Tech
