Question about Philips Magnavox 20MT133S 20" TV
GET SOUND BUT NO CLEAR PICTURE ONLY HORIZONTAL LINES form bottom to middle black blur lines
  • 998 Answers
Try to check your cable connectors it might be loosed.
Posted on Oct 14, 2010
    Top Expert:
  • Philips Master
  • 75,462 Answers
Video output section of your tv is in trouble. Either it not gets proper voltage [low voltage if voltage is there]; or video output Ic or transistors whichever used may got damaged. Never switch on the tv in this condition; that picture tube may get damaged. Get it repaired soon.
  • sonny cortez
    sonny cortez Jan 15, 2014
    check the vertical ic or resistor fr.flyback to vertical section.,if you are a technician you know that., but if not bring it to nearest electronic shop.,
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
Horizontal line on screen sometimes
Generally horizontal lines are caused by the panel failing, you can try a new tcon but I don't think it will help.
Mar 01, 2018 | Philips FTR9955-17 DTV Receiver
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
Apr 05, 2009 | Toshiba CF32H40 32" TV
Horizontal Line through middle of TV screen
This is usually a bad elect capasitor or a bad solder connection on the vertical IC, The capasitors will be close to the vert chip..Sometimes you can clear problem with a light tap on the TV, if so then suspect bad solder.
Charlie
Mar 31, 2009 | Televison & Video
That sounds like simple ring-cracks in the vertical circuit, most likely the vertical Ic itself... On the printed circuit side of the Tv look at the vertical Ic and examine it carefully under some magnification where each pin of the Ic solders to the board. See if you can find any cracks in those solder connections.
Bill
Feb 04, 2009 | iLO V27DMBX Television
Permanent horizontal black lines on my 50
Ive got bad news for you, about 90% of the time black horizontal lines are caused by the panel failing, your going to need a new TV. You can try replacing the timing board but the chances of it fixing it are slim..
Jan 06, 2018 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Horizontal bands
you may have a problem with the vertical output IC.
May 26, 2007 | RCA F27442 27" TV
Philips Magnavox 20MT133S 20" TV Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
