Question about GE Profile WPRE6100G Top Load Washer
SOUNDS LIKE BEARINGS ARE GRINDING WHEN WASHER TUB SPINS
    Problem Solver:
  • 87 Answers
U need to gease the bearings
Posted on Oct 14, 2010
My washer spins slow and makes thumping or grinding noises and leaks a little in the back
Sounds like your bushings or bearings have gone bad in the transmission. Need to replace the transmission and all the seals in the wash tub
Apr 10, 2015 | Washing Machines
My Frigidaire FWT645RHSO front load washer sounds like a propeller airplane when it spins...HELP!
Robin, it sounds like the tub bearings may be going out on your machine. With the washer empty, reach inside at the top and gently lift the inner stainless steel tub. Does it move up and feel like there is some slop or play in the tub. If the bearings are tight, the inner tub will not move much at all independently of the complete outer tub assembly.
Have you noticed any grease on any clothes recently? Usually what happens is the water seal fails and the water eventually washes the grease out of the bearings and they fail.
Depending on your skill level, there are some good online blogs about tub bearing replacement. You may not want to deal with it. You have to make the call on that. Thats my 2 cents worth. Good luck.
Mar 19, 2014 | Frigidaire Washing Machines
When the washer spins with a heavier load like towels or jeans, it makes a horrible sound off and on. It sounds like something rough scraping against another rough surface. Is this something my HVAC...
Sounds like the bearings may be going out. Quick check for bad bearings: Open door, grab spin basket lip, yank on it; up and down works best. If you can get your fingers on the white plastic outer tub lip try to determine if the metal spin basket is moving independently from the outer tub in any motion other than round and round. If so you're rear bearings are becoming worn and will be especially noisy under a heavy load.
Jan 06, 2011 | Whirlpool GHW9100L Front Load Washer
Grinding noise when in spin cycle
Sounds like a worn pump or the tub bearings are worn.see if the sound is there before the bowl actually starts to spin,if so then it's the pump.(the pump runs for a while before the bowl actually starts to spin) a good way to tell wether its pump or tub bearings.
May 30, 2010 | Fisher and Paykel GWL11 Top Load Washer
Machine noiser than it use to be when tub spins
From the front of the washer, spin drum by hand, and if it feels rough or is noisy, then the main drum bearings are probably worn.
Another possibility is the motor bearings noisy, or a worn armature.
If the noise is gradually getting worse, then I think it is safe to say it is the main bearings.
Jan 26, 2010 | Hotpoint WMA40 Front Load Washer
Very loud spin cycle
It sounds like the bearings have gone out in the tub. The major cause of this is using powder soap. There is nothing you can do but replace the rear outer tub. This is a costly fix but maybe worth it for a stack unit.
Jun 26, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Frigidaire front loading washer makes a clinking noise
It sounds like your tub bearings are starting to go bad. Mine sounded like airplane taking off. Once the seal goes bad, water tends to migrate into the bearing cavity and flush the grease out of the bearings and then they wear quickly.
You have to completely remove the tub assembly to take it apart. Some say get a new washer, but I only paid $60 for the 2 bearings and a seal from a bearing house. They are even cheaper online.
You may as well try and fix it, worst case the junk yard doesn't care if it's in pieces when you bring it to them. I have no idea what an appliance repairman would charge to fix it.
If I remember right the seal is a 80mmx40mmx10mm metric seal. I found a rubber coated one from SKF I believe. The bearings should be 6306-2rs and 6307-2rs, but I would not buy anything till you have it apart. The bearings knock out easily.
INFO-Mine had -2z bearings installed which are only shielded bearings. The -2rs bearings hold up much better to water exposure in case the new seal leaks in the future.
If you want the exact seal part number, I can get it off my paperwork, Just write back.
I saw somewhere on an appliance blog that had step by step pictures of the procedure.
Jan 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer FWT449GFS1 grinding sound
If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly and the outer shell with the tub bearing.
Sep 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
GE Profile WPRE6100G Top Load Washer Logo
93 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
