Question about Electrolux Epic 6500 Vacuum
I have some sort of object in the hose of my Epic 6500. I have tried reversing the hose and blowing out the foreighn piece of debeis but this has not worked. Is there a way to remove the plastic connector end to access this end of the hose? Or is there another solution to this problem?
  • 694 Answers
By reversing it, I assume you plugged the hose into the exhaust blower on the top of the machine. If so, insert the other end into the intake and turn one the vacuum. This way the clog is also getting sucked at what should be the loose end.
If it's a sock or similar item, it will be more difficult. Yes, the handle can be removed, but can sometimes be a bit difficult to put back together for someone not real sure of what they're doing. I've seen several hoses ruined by having sharp or pointed objects inserted to clear a clog, cutting the hose and/or wiring, and ending up burning it up. I recommend taking it to a shop and letting a trained technician take care of it. An authorized Aerus Electrolux dealer would be best.
Posted on Oct 14, 2010
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Accessory compatibility between Electrolux Models 1521 and Epic 6500 SR
No, they have different connectors. 1521 uses a pigtail hose that has little metal clips. 6500 has a plastic end with an arrow that helps guide you for proper placement. Unfortunately you will need 2 separate hoses for the respective models.
May 12, 2015 | Electrolux Vacuums
Unclog vacum hose
Disconnect the hose from the canister and connect it to the blower end of the canister and this should blow out the debris or rag stuck in the hose.
Jul 21, 2013 | Electrolux Epic 6500 Vacuum
Small potato (yes) stuck in hose, dont know how to reverse. tyvm
Possibly, find the location in the vacuum hose, where the potato is stuck, squeeze the hose there to force the potato to break up into smaller pieces that can be sucked through. If it is stuck in the "wand" the solid part, a straightened out wire coat hanger, may suit, instead, but be extremely careful with that, as the wire may pierce the hose. Alternatively, you can reverse, by plugging the hose into the "exhaust" .
Apr 24, 2012 | Electrolux Epic 6500 Vacuum
I have an Electrolux Epic 6500 SR vacuum and the hose end with the handle is separating. Power nozzle losing contact intermittently. Is this piece replaceable or repairable?
It is replaceable. Just take it to the nearest Aerus Electrolux store and the service tech will take care of it for you.
Go to the following site and follow instructions to find the stores nearest you.
Nov 18, 2010 | Electrolux Epic 6500 Vacuum
Hi I have something stuck in the handle of my Epic 6500 series vacuum cleaner. How do I detach it from the hose? Thanks Marina
take your tool caddy off and after filter insert the hose into the exhaust port turn the vac on the object should come out you may have to place your hand over the handel to build up back pressure a few times if it doesn't come out at first
Aug 02, 2010 | Electrolux Epic 6500 Vacuum
Electrolux Epic 6500 Vacuum - Suction stops when hose is attached
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial.
You can ship the vacuum to http://evacuumstore.com/ and they can reapir it for you.
Mar 28, 2010 | Electrolux Epic 6500 Vacuum
I have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
I need to remove the handle of my Eletrolux 6500 from the hose.
If it is in the tube part of the vacuum, you could poke it out with a long and skinny pole, or a meter stick. If it is stuck in the hose, just open up the part that closes the vacuum bag, and do the same with a very long piece of metal or wood, as a meter stick will not be long enough.
May 31, 2009 | Electrolux Epic 6500 Vacuum
Electrolux EPIC 6500 won't stay on
find and clean all filters,if an air compressor is available take it apart what you can and see if you can get to the motor and blow it out and check for restrictions in hoses,motor has overload protection and dirt will make it overheat and shut off when it cools down then it works again and or check electrical cords and sawitches
Feb 07, 2009 | Electrolux Epic 6500 Vacuum
Vacuums Logo
79 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
