Question about Refrigerators
Need manual for Caloric Prestige Series side by side refrigerator/freezer with Ice maker model # GFS227-1W 00 Serial # S84023934
  • Wayne Myers
    Wayne Myers Oct 15, 2010
    I appreciate your response, unfortunately the Caloric company is no longer around, they were taken over by Amana, later Amana was taken over by Whirlpool. I have never had an ice maker in a refrigerator before, do you know if the wire lever is suposed to be in the up or down possision to make ice??
  • 6,993 Answers
unfortunately, the user manual for your
Caloric Prestige refrigerator/freezer is not available anywhere online. The manufacturers of this product did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacturer of your
Caloric Prestige refrigerator/freezer via phone or e-mail and request for the manual from them. They might give it to you or direct you to a dealer where you can get the user manual.
This is the best you can do to get the manual you are requesting for.
Good luck.
Posted on Oct 14, 2010
  • Walesarumi
    Walesarumi Oct 15, 2010
    There should be a silver metal bar - really thin - above where the cubes come out. Just flip it down to make ice.
    To turn it off, flip it down.
    Take care.
No ice being made
is the arm up for the ice maker to run? sometimes the arm gets bumped and shuts the ice maker off. some it needs to be up some it needs to be down.
Dec 31, 2011 | GE GSS22JFPCC / GSS22JFPWW Side by Side...
Ice maker not working
There is a tub that goes through the back of the freezer wall into the ice maker. Sometimes this tube will freeze shut and needs to be thawed out.
The water fill tube will freeze shut from low water pressure. Ether from a bad water valve or low pressure to the refrigerator itself.
Pull the refrigerator out and remove the tube from the back wall to check it.
Also note that,
Sounds like the thermistor is bad in the ice maker itself, and there are 3 more micro switches, and some other things in there too, just easier too replace ice maker than parts for it.
If it turns out to be the ice maker, look on the tag in the ref. side, which list the model number and serial number. look @ bottom of that tag, it will give you a model number for the ice maker kit you need.
Good luck and hope this helpout......
Jul 30, 2010 | LG LFX25971ST Bottom Freezer French Door...
Looking for wiring diagram for amana bottom freezer model # BG20T2L MFG# p1316303wL serial # 9807110676 THE ICE MAKER QUIT MAKING ICE
First thing to check is the fill tube and make sure it is not frozen with ice.some ice makers can be manually advanced in order to refill with water some have a reset button to do this if these two things do no good and the fill tube is not blocked with ice then repalce the water fill valve on the bottom rear of the unit
Jul 10, 2010 | Amana SXD524VW Side by Side Refrigerator
Ice sheet on back of ice maker & in ice bucket
Happy 20th Birthday Refrigerator. Time to replace.
Jun 25, 2017 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a brand new (2 days) Frigidaire Gallery series, 23CU side by side that is not making enough ice. We are getting water from the door, the ice maker will only drop about 3 times in 24 hours. the...
Good day,
Light usage in a cool kitchen will reduce ice production substantially.
When the ice maker harvests, it turns on a calrod unit located on it's bottom, that frees the cubes, and as well the heat from the calrod heats up an internal thermostat in the ice maker to a temperature in excess of 70 degrees.
Then it stays at rest, until the cycle thermostat reaches 12 to 14 degress and then performs another harvest cycle.
If the machine runs little, and the fan in the freezer is not circulating cold air, the harvest times will be extended.
Turning the freezer colder will always help.
There is a possibility, the thermostat in the ice maker is out of calibration, and the ice maker needs replaced. But try the settings first, and give it a week or two, before calling for service.
You have a lot iof time under warranty to resolve this issue.
Thank you for using FixYa.
Jan 08, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Icemaker leaking
Check two things.
1: see if you have ice buildup in the water inlet tube above ice maker, if you do chance are the water valve is bad, if not,
2: see if you have icicles hanging from bottom of ice maker, if you do you have a bad ice maker.
Either way, will need full model number and serial number both to get you the right part numbers for parts.
Oct 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer and Fridge are both not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hhsg
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
158 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
