Question about Canon BJC S600 InkJet Printer
Paper will start through printer
Paper will not go through printer. it says thickness lever not to left. it is.
    Genius:
  • 1,224 Answers
I think its asking if you are using right kind of paper specified to be used with your printer there are alot of different types of thickness in paper out there make sure your using the right one
Posted on Jun 02, 2008
  • 390 Answers
SOURCE: Paper jam
OK, first try resetting th printer. This sometimes works the first time and corrects a lot of issues. Switch it off, take out all paper, check for jams with a torch right down back and open cover and check ther too. Once you are sure there are no paper jams (look really carefully they can be tiny!) unplug all cords and cables. Plug all back in turn it on, and try printing again. Post back if no luck and i will further assist.
Posted on Aug 31, 2007
The Machine
  • 788 Answers
SOURCE: Paper thickness lever postion
Is there a lever inside the printer that can be moved back and forth? If so set it about half way and try again.
Posted on Jan 17, 2008
SOURCE: Printer won't print
The lever is right above the ink cartridges. Turn on your printer and open the lid like you would to change the ink. You'll see a small blue lever that has two positions, left for regular paper and right for envelopes.
Posted on Mar 24, 2008
SOURCE: thickness lever
I just bought one of these printers and got the same message when trying to print from my digital camera... All you have to do is press the OK button on the printer!!! Don't feel too bad.. there is no documentation that explains this.. I only found this after I started frantically pressing all the buttons on the printer out of frustration.. Good one Canon.
Posted on Apr 04, 2009
pineworks
  • 4041 Answers
SOURCE: hOW DO i FIND THE PAPER THICKNESS LEVER SO CANON S330 WILL NOT JAM?
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 26, 2010
Can I use thick paper to print on Epson DX 8400? Is there any way to adjust the thickness of paper?Thank you.
There is a Paper Thickness lever on the left hand side of the front of the printer. If you go to the following website:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?infoType=Doc&oid=58606&prodoid=56291067
You can get the Product Information Guide, or the User's Guide. Both of these will describe which setting you should use for a wide variety of paper. For normal single sheets of paper the lever should be in the down or "L" position. If you are using envelopes the guide instructs that the lever should be in the up or "H" position. They give you a complete table with the appropriate settings to use depending on the thickness.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 19, 2011 | Epson Stylus CX4800 All-In-One InkJet...
I've had the printer for about 18 months with no problems. I need to print envelopes for the first time, and can't figure out how to do it. Any help out there?
Load the envelope against the right side of the back paper tray.
Load with the address side facing UP and the rear flaps DOWN on the left.
Pinch the Paper Guide and slide it against the left side of the envelope.
Set the Paper Thickness Lever to the right, return to the left after finishing printing.
The Paper Thickness Lever is located inside where the paper come out of printing.
Specify the settingin the printer driver.
Select Envelope in Media Type
Select DL Env. or #10 Env.
Select Landscape in Orientation.
Jan 18, 2011 | Canon PIXMA MP470 All-in-One Printer
Printer will not function. paper thickness message i550
Hi
Thanks for using FixYa. To resolve the issue of paper thickness message you’ll need to turn your printer on and open the lid and there is a small blue lever having two positions, left for regular paper and right for envelopes.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 24, 2009 | Canon Office Equipment & Supplies
Dont know where to put paper in
The input paper tray for the iP1800 is accessed by opening the door / tray in the top of the printer. The door serves as the back support for taller paper. The paper thickness lever below the output roller needs to be adjusted depending on paper thickness. Most papers require that it be kept in the left position.
You can view the entire details of the printer by checking the details at:
http://www.printerinfo.com/content/Canon-Pixma-iP1800-Photo-Printer-Review-676/TourComponents.htm
Sep 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Will not print and keep getting paper thickness error
Did you try moving the paper thickness lever (blue lever on top of the print cartridge holder)? It should be all the way to the left when you start--if it needs to be adjusted the printer message will let you know.
Jun 27, 2009 | Canon i850 InkJet Photo Printer
Ink smudge on envelope
dvlknc
The paper thickness lever is not on the front...it is on the floor of the "paper output tray" chamber. It is hard to see without directed light.
Refer to Loading Paper section of the Quick Start Guide....p 15 2 Prepare to load paper
(4) Adjust Paper Thickness Lever
(See diagram)
Or look at the "User's Guide on-screen manual" as directed by the Note on p. 17
I really had to search to find this lever while attempting to resolve my problem with a badly aligned printing head. I am going to have to buy a new printer. It definitely won't be a Canon due to the rip off cost of print cartridges.
Hope this is helpful.
kellyplus
Nov 14, 2008 | Canon PIXMA MX310 All-In-One Printer
Paper thickness error not clear
i have a brother DCR375CW and it will not print on card it keeps saying no paper feed , how do i set it for card thnaks
Sep 29, 2008 | Office Equipment & Supplies
Jsut plugged in machine
The Paper Thickness Lever should be set to the left for normal/plain paper. This switch can be seen inside the unit in the area of the paper output tray.
May 22, 2008 | Canon PIXMA MX310 All-In-One Printer
Printer won't print
I know that the paper lever is where your paper is loaded. Check the grey plastic tab and try to drag it to the right or left. Depending on your paper size you might have to check the owners manual.
Mar 03, 2008 | Canon BubbleJet i560 InkJet Printer
Canon BJC S600 InkJet Printer Logo
old marine
old marine
