Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a 70 series 110 20702990. When the unit goes into spin cycle it seems to create too big a load for the motor. The motor starts a series of load clicking noises like a relay or solenoid are turning on and off and eventually the circiut breaker will go at the electric panel. It does it whille empty and while full. I had it apart and the motor did spin the drum with the water pump out of it.
  • Steve Lesyk Oct 18, 2010
    It's starting to look like the motor itself. The brake and clutch system look great, I cleaned and greased the drive tubes from the transmission, and tried a new pump. The motor overheats very quickly even while agitating in wash mode and the thermal breaker switches off.
  • Kenmore Master
  • 8,220 Answers
Did you look in the water pump? Sometimes things get into it. Other times sand gets in there and locks or binds the bearing. Even makes it melt!
Posted on Oct 14, 2010
Hello, Have a Kenmore series 70 (capcity plus).
Note after reading a bunch of information. I went home and removed the hose from the Level Switch and "clean it", if you will and re-attached. Started a load, and bingo bango bongo, it work. Thanks for the insight.
Nov 30, 2009 | Kenmore 22422 Top Load Washer
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 70 series washer requires push to spin (sometimes)
You have a defective brake. It must be replaced.
Aug 30, 2009 | Kenmore Washing Machines
Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Aug 27, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
70 series washer does not spin
this is pretty bad, defenitly you need you need to call a repairman, something is slipping in the transmission
Jun 17, 2009 | Kenmore 22422 Top Load Washer
My kenmore top loading washer 70 series wont go into spin cycle
check the lid switch some washers will fill and was with the lid open but will not spin, if the lid is closed manually actuate the lid switch or bypass it electrically, or replace it.
Apr 07, 2009 | Kenmore 22422 Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
83 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
