Question about Hotpoint Ultima WF860 Front Load Washer
My washing machine is showing test
My washer shows on the lcd screen "test"whenever i try to do a cylce, but nothing happens. can you help me solve my problem?
  • Anonymous Jun 02, 2008
    cannot cancel test cycle
  • Stewart Briggs
    Stewart Briggs Jun 03, 2008
    My WF865A is also showing test....any ideas?
To Deactivate
Press the Start/Cancel button until all the console LED's illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Note:- The default screen information displayed on these models is that of the programme currently selected by the selector knob.
Posted on Jun 03, 2008
Thank you very much!!!!it works!!! you're a heaven sent!!!!
Posted on Aug 10, 2008
I have a 10 beep continous and showing e90 on my frigidaire washer, what will i do?
E90. The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
Basic Reset
One of the first steps whenever an error code appears on a Frigidaire washer is to perform a simple reset to the machine. To reset the washer, press and hold the "Cancel" button for 15 seconds. Then try to set a new wash cycle and press "Start." Note that any clothes that have finished washing should always be removed promptly after the cycle is done.
Feb 26, 2014 | Frigidaire Washing Machines
Panel is switching back between 6 and F at the end of the cylce
http://www.applianceblog.com/mainforums/attachments/sears-kenmore/639d1187051794-he2-error-codes-he2-error-codes.pdf
Above is a link for the error codes and what they mean.
http://www.servicematters.com/maytag_library/docs/16007803.pdf
Above is your service and repair manual. with troubleshooting steps, to isolate your issue.
Jun 22, 2010 | Kenmore HE2 Plus Front Load Washer
My washing machine stops at the middle of the cottons and pre-wash programme and the timer shows different times most of the time e.g. For the cottons and pre-wash cylce it sometimes shows 1hr47mins and at...
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long. Below is given a procedure not exactly for your machine, but it could be a lead.......(its for the whirlpool duet)
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 19, 2010 | Washing Machines
I hear gravel noise when the machine changes cylces
The machine does a quick test to determine if the spline is engaged before spin commences. The way it works is the tub fills with water and floats for wash. When the pump removes the water for spin the spline don't always line up. So artificial intel will give it a slight test to see if the basket is locked. I have a bravos manual that shows how it works I know yours is an Oasis but I believe these are all basically the same. See page 23
Apr 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a mah5500b. prob is washer will not start or do anything. it just beeps. tried the diagnostic test. by pressing delicates and heavy soil. led shows 00. when i push other buttons to check functions....
I had a similar problem on my Neptune. All the machine would do is beep. I believed it was a stuck button so I got a new touch pad and that solved the problem. I also substituted a control board prior to buying the touch pad but the problem was the same.
May 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Showing test on the screen
hi the same thing happened to me i solved it by holding the 2 buttons in
Jan 04, 2009 | Hotpoint Ultima WF860 Front Load Washer
Odd messages appearing on lcd screen and not collecting water
What make and model is your washer?
Cannot help without further details
Nov 19, 2008 | Hotpoint Washing Machines
Reset the washer
GE Profile Harmony
1 press power ( to wake up washer)
2 press Home ( it may already show HOME)
3 press HELP
4 press and hold MY CYCLES and BACK (for 3 to 5 seconds)
the service mode diagnostics screen will come up
it will show what errors are recorded..( if more button is displayed then also go to next list)
be sure to write them down exit will clear the codes and run a test
let me know what it tell you I can help...
Aug 21, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
I seen that you might know whats wrong with my washer???
3 press HELP
Aug 20, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Hotpoint supersilent washing machine
Try pushing the "on" & "start" buttons together for 5 secs or more. If it does not clear from the display, switch of the machine for 5 mins and try again.
It would be nice if you rate me, thanks.
Dec 26, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
119 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
