Question about Belkin (F5D7230-4) Router (587009)
Disc loaded connection exc. still can't get on to internet
Belkin g router f5d7230-4 connection on main computer running xp good, laptop running vista show blue light still unable to get onto internet.
the router came with one blue cable and the instructions has two.
the cable from my cable router to the computer ic a usb cable .
i have acable that will join the cable router to the computer, do i leave both cables in or remove the usb one.
    Problem Solver:
  • 8 Answers
Lets start at the beginning, you should have a DSL/CABLE modem that connects you to the internet to begin with now. It would be helpful to know the Manufacturer and model of that device. There were probably two possibilities on how you had your internet set up before. The modem could be a modem/router with only one port in which the router supplied the username and password to access the internet. If this is the case you will need to hook a computer up to the modem directly access its default IP address usually 192.168.1.1 or .254. To access this device you will have to manually set your IP address to a address that is on the same subnet. You do this by going to network connections in control panel right clicking the Local Area Connection and clicking properties. Then scroll down in the box until you see TCP/IP click on it and hit the properties button. Set your ip address to something like 192.168.1.50 and a subnet of 255.255.255.0. You will need to change the routing pattern to Bridged Ethernet. This will allow your new router to do all the work. You will then need to hook your modem directly to the WAN port on your router and connect your computer to one of the switch ports on the router. You will then need access your router by using 192.168.1.1 or .254. You will need to set the PPoE Information i.e. username and password. Now you will need to go back to your network connections and change your ip address back to the obtain automatically. Your internet should kick on and start working. If i have made any wrong assumptions please let me know and I will follow up with a more detailed response.
Thanks
Chris Lower
Posted on Jun 03, 2008
I baught this belkin router at a yard sale,when I got it there was no disc to install it on my computer,I have hooked it up and it says I am connected but when I try to get on line it can't find the sever.
From what I can tell you are using Mozilla Firefox Try using Internet Explorer if ip address id not valid it will tell you Internet Explorer cannot display webpage In order to renew ip address these are the steps you will want to take:
1. Ensure the equipment is connected correctly(Ethernet cord from modem to Internet port on router
2.Open network connections Win XP:Start/Run/Type ncpa.cpl
Vista/Win 7 Start/search bar/type ncpa.cpl
3.This will bring you to your network connections window
4.If using XP: Double click on wireless connection and hit the support tab. Ensure it is assigned by DHCP and the ip address should start with 192.
5. If Vista Or Windows 7 Right click on wireless conenction and hit properties. Uncheck version Internet Protocol Version 6
6. Click and Highlight internet protocol Version 4 and hit properties
7. ensure that it shows obtain ip address and obtain a dns server automatically
8.After go to Command Prompt (Win XP) Start/Run/Type CMD
Windows7/Vista:Start Start/All Programs/Accessories/Right click on command prompt and hit run as administrator then hit continue type in these commands.
1.netsh int ip reset reset.log
2.netsh int ip delete arpcache
3.netsh winsock reset
4.ipconfig /flushdns
9. Restart Computer hope this helps please rate thank you
Sep 30, 2010 | Belkin (F5D5231-4) Router
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
2nd computer not connecting to internet
i m using this router
and problem i m occuring is that..i can only run one thing at time
i m using iphone ma laptop and e63
when iphone is using it...other things do get connected but dun get internet access
when i use e63 it gies an error of no gateway reply after it gets connected to router
plz help me that how can i run three things at one time without getting disconnection
Apr 14, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
XP PC connects/Vista PC doesn't/Connectivity issues
On the Vista Computer
Goto
Start>Control Panel > Network and internet > Network and Sharing center
On the Left Hand Side Click on Manage Wireless Networks
Remove your network From the List
then
Start > Connect to> Click on ur Network > Click Connect
Dec 22, 2009 | Belkin F5D7234-4 Router
Belkin router F5D9230-4 connection issues
First thing to do here is to reset the router, Press and hold the reset button for 15 seconds while the power is ON then after that unplug/replug the power for 5 seconds then run again the setup CD and if the router is still working after the reset it should be configure by the setup CD, if not I will advice you to contact Belkin tech support so they can further check if the router is bad already and if its still under warranty they can replace it....
Hope that helps..........
Sep 19, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Installing wpa security belkin f5d 7230-4 router
youre supposed to type it in when connecting to the wireless. if it wont connect. click the lil star on left on the "view wireless connections" in xp then remove the named router in the list bellow.(it stores old password) and wont connect with old password.
Aug 20, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin wireless router installation with a laptop that has an internal modem
Depending on the operating system that you are running, and if you have the appropriate wireless cards, you should be able to do this either with or without the modem. If you have the modem connected to one computer, and wireless cards on both computers, then your best option would be to just connect directly from one computer to the next. If you can tell me the answers to these few questions, I can help you get on the right path.
What operating system are you running? Windows XP? Vista? Macintosh?
Do both of your computers have wireless network cards? If not, then which computers have the wireless network, and which computer has the modem?
Feb 02, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Wireless computer won't connect to internet
Somewhere in the network connections settings I recall seeing a checkbox to tell the laptop to automatically determine the IP address when connecting (as opposed to using the same one every time). Sorry I don't recall more specific directions ....
Jan 01, 2008 | Belkin (F5D7230-4) Router (587009)
I cannot run internet with my router
downgrade your vista to windows XP Pro or XP home..
Nov 07, 2007 | Belkin (F5D8231-4) Wireless Router...
Belkin wireless router model 7633
First go to the desktop pc and go to your Belkins router access screen, and reconfigure the wirless part and reboot the laptop and the router
Oct 20, 2007 | Computers & Internet
Belkin (F5D7230-4) Router (587009) Logo
75 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
