Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Canon SD400: horizontal lines and daylight images are overexposed (see photo)
I have a Canon SD400 that is having problems with the images. The photos have horizontal lines running through them.
Also, the outdoor photos, anything with sunlight, comes out overexposed. However, movies come out normal. This is all in automatic mode.
Any solutions? I could not find any recall info for the SD400 if this is a CCD image issue.
Here's a sample photo:
http://i225.photobucket.com/albums/dd151/rcjunkie3000/Canon%20SD400%20Image%20problem/IMG_0581.jpg
  • Tom McCarthy
    Tom McCarthy Jun 03, 2008
    having the same overexposure problem. no issue with horizontal lines. seemed to occur after the camera was tipped over, perhaps shock damaged something. Indoor pics are fine, only seems to be a problem in bright sunlight.
  • 188 Answers
In both the situations the problem is with the apperture control mechanism of the camera. 1). sometimes the flexible ribbion cable carrying signal to the lense assembly get worn out, replacing the same will resolve the problem. 2) in some cases the leaf blades of the apperture gets sticky, cleaning of the same solves the problem. 3). If you happen to drop the camera then the alignment of the motor moving the blades get disturbed.
In all the cases only a good repair man can fix the problem .
Posted on Jun 07, 2008
Canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture...
The shutter flex cable inside the lens is broken. Happens to all cameras from Canon A4xx series. At day the images will be overexposed with horizontal lines on it, but it could look better at dark / night. The FLEX has to be replaced. Canon doesn't supply new flex cables for these, but there are some cheap copies on ebay. But as these brake very often, I wouldn't suggest you investing money in this camera, because it will brake again sooner or later.
Jan 26, 2011 | Canon PowerShot A470 Digital Camera
Canon IXUS50 overexposing each photo - white balance problem?
Hello. go into your menu and find the reset function. Reset the camera and try it. If the reset to factory settings doesn't solve your problem it needs to go to the repair shop. Joe
Apr 05, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture there's a horizontal line appears in the picture..
Dec 21, 2009 | Canon PowerShot A470 Digital Camera
Photos are over exposed when taken in daylight
i am facing same problem with my canona430 camera , I have been using for the past 2.5 years. I went to authorised service center & they told me the prob. is due to over exposure & repairing cost will be around Rs.3000/-(approx. USD 60) with bill
Oct 14, 2009 | Canon PowerShot A430 Digital Camera
No photo in daylight in outdoor
You'll need to first check what setting you have the camera on. Sometimes, this can make all the difference. Change the setting to auto. Or, if you are familiar with manual settings, change the camera mode to manual...then change the ISO
Sep 13, 2009 | Canon PowerShot A450 Digital Camera
Overexposed photos in otherwise normal settings in casio ex-s500
It is the shutter (or at least it was for me) I found a simple test here: http://www.mydc.com.tw/repair/knowledge_en/casio-exilim-ex-s600-overexposure-t17.html
I repaired it myself, but it took me a whole afternoon and lots of patience.
The hard part is taking the camera apart, once I got to the shutter I just activated it manually so to dislodge any pieces that might have gotten jammed, then placed it back together again and it worked! :).
It's really hard to take apart, it's like a puzzle sometimes, to find which screws are keeping it together. I also had a bit of hard time when it came to put the zoom back together again.
But I guess it beats throwing the camera away.
I'm still puzzled on how the CCD works so that an overexposure would make horizontal overexposed lines, but everything points to that. Fixed shutter, lines be gone.
Apr 29, 2008 | Casio Exilim EX-S600 Digital Camera
Pictures overexposed in daylight, visible lines in photos
1. Adjust ISO or ASA 100
2. Adjust AWB Indoor florescent or Bulb while outdoor select sunny or foggy it depends of the place
Dec 25, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Canon powershot
Repair shop or replace - unless you are into taking stuff apart but in this case it is a major component failure I feel
May 30, 2007 | Canon PowerShot S1 IS Digital Camera
Poor image displayed on cscreen after shot taken
I have an s60 and it sounds like I had this exact problem. Whenever I took a photo, the entire picture was covered with white horizontal lines. The actual image files were striped the same way.
I found this on the Canon USA site:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=223&modelid=10149
Because it was a hardware issue, they sent me a shipping label, I sent in the camera, they fixed it, and sent it back. All free of charge.
Good luck; I hope your camera is repairable.
Aug 24, 2006 | Canon PowerShot S60 Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
277 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
