Question about Dryers
The drier has stopped ratating, there is power, but when we try it start it it just hums. How do I checked to see if the belt has come off or could it be something else. Thanks
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 15, 2010
Drier makes humming noise, and won't spin
check for a problem start/run capacitor for the motor
there may be a overload button that has popped out
Jan 09, 2016 | Washing Machines
My drier powers up and everything but the timer is lit. and the drier wont start
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
May 19, 2015 | Dryers
Why is there no power getting to my tumble drier, what could be the problem?
Aug 10, 2014 | Whirlpool Dryers
How to get to motor on hoover vhc691b?
Very rare a motor fails on a hoover drier normally its the capacitor that fails. you can hear the motor humming but the drum wont rotate to proof its the capacitor turn the machine on press start listen for the motor humming open the the door of drier turn the drum by hand fast then shut the door as fast has possible then the drum should start going around . then this proves its the capacitor fault you are doing the job of the capacitor giving the motor a start .
May 16, 2014 | Hoover HDC6 Electric Dryer
My EDE05 drier has stopped working. Lights are still on, but no rotation.
A likely suspect is the belt which may have broken. If it broke while the duvet was being dried, it could have gotten roasted in the stationary drum.
May 26, 2017 | Dryers
I have an admiral electric dryer. It stopped in the middle of a cycle and the light is out and it won't turn on. I checked the fuse box, the plug and the belt is still on, so what do I do now?
Did you test the power outlet with another device...Sometimes a power outlet will fail under the load of a high current appliance like a drier...If the drier runs on 220 volt current...and have circuit breakers instead of fuses...make sure the 220 volt breaker for the dryer is not tripped...If it is tripped...reset it....if not...have a tech to check the outlet. oncee it is established that the drier is getting power and still not working...you may want to get it checked out by service personnel....Hope this was helpful....PEACE.....
Jan 25, 2012 | Admiral Dryers
Amana LE7153WM drier will not start... makes a low humming sound when you push in the select dial to start the drier
Hi John, W/D here.
Most likely scenario: squealing was either a belt or a bearing. Failure to run is probably a broken belt. Gain access to the back of the drier, with the power disconnected. Open the back and check the belt. If broken, replace it, and then rotate the drier by hand, listening for additional squeals and squeaks. If no other issues are noted, replace the back cover, plug it back in and try it out.
Best regards, --W/D--
Nov 09, 2011 | Dryers
The drum fails to start spinning, a humming sound is emitted. there is black residue around the idler pulley, but the belt seems o.k.
There might be a problem to the starting capacitor of your drier. Check the capacitor if it is working or not.
Nov 01, 2010 | Zanussi TD4212W Electric Dryer
Dryer starts but then slows down and stops and won't start again until it's cooled down. Motor feels hot.
probably the connection of start button is loosen the wire, then maybe you need to replace the wire i think it mabe tilted and some other ways you need to check the motor, the pump belt and the right ways to put your clothes in the drier thankx.
Mar 02, 2010 | Dryers
Dryer just stopped running
2 quick ones come to mind. 1)Check the door limit switch. If it goes open circuit, there will be no operation. 2) Surprisingly, on some driers, there is a hidden fuse in the wiring loom.(referring to the larger driers). If not the problem, does it hum as you press the start?If not, switch off, open panel and trace wiring back and observe for any burned or broken areas.
Sep 28, 2009 | Crosley CDE6000 Electric Dryer
Dryers Logo
22 people viewed this question
Top Dryers Experts
