Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
Touchpad won't work - Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
    Problem Solver:
  • 87 Answers
U need a new touchpad
Posted on Oct 14, 2010
My Asus Q500A-BHI5N01 touchpad won't let me scroll with the two finger gesture. The mouse works fine, but the touchpad isn't nearly as responsive as earlier. This is a new computer, less tha
Open the touchpad software, ASUS Smart Gesture, adjust sensitivity. Asua support : http://support.asus.com/Troubleshooting/detail.aspx?SLanguage=en&m=Q500A&p=3&s=450&os=&hashedid=n/a&no=1018
Jan 10, 2013 | Computers & Internet
Touchpad won't work after computer has been unlocked
Windows has always had this quirk about not functioning correctly after it goes into sleep mode. Check your Screen Saver options, and Power Options Properties. Change Turn off hard disk and System standby to Never. You will find these options in Control Panel.
Oct 13, 2012 | Gateway M460 Notebook
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
Sep 28, 2012 | Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
Installed win 7 on toshiba m305-s4819 now touchpad and keyboard won't work't work
you will need to find the correct drivers, and this will fix your problem
Jun 07, 2012 | Toshiba Computers & Internet
Hi, my new asus laptotp touchpad doesn't scroll. Some idea how to set it up? Thanks
If you're using windows XP on your laptop, please try the link below
Driver for Touchpad
If the above link won't work please try the other one below
Driver for Touchpad
Thanks, hope this works!
Sep 13, 2011 | BenQ Joybook 5100U Notebook
Dell touchpad not working, what can I do? It won't
download or update drivers for touchpad. and your good to go.
Jun 15, 2011 | Computers & Internet
Built in mouse has not worked properly from day 1. Now my external mouse won't work either. I tried a different external moue, but it doesn't work either.
Unplug everything except the power cord, including the following:
Speakers
Printers
Scanners
USB devices
Personal Digital Assistants (PDAs)
USB flash drive or other external storage devices
External Monitor
External Keyboard
External Mouse
If your computer is attached to a docking station, undock it.
Make sure the touchpad or your finger has no dirt, grease, liquids or food on it (the touchpad has to make a good contact with your finger to work correctly).
Turn the computer back on and retest the touchpad.
When the touchpad still does not work correctly proceed to step 5.
When the touchpad does work correctly, attach one external device at a time and test the touchpad to see which one may have caused the issue.
Make sure the latest driver for the touchpad is installed (you may need to use a external USB or Bluetooth mouse), for more information refer to:
"How to Use the Drivers and Downloads Website"
May 26, 2011 | Dell Inspiron 1525 Laptop
Travelmate 4200 touchpad mouse doesn't work.
go to the computer hardware point or servicestation.
Mar 06, 2009 | Acer TravelMate 4200 Notebook
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
79 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
