Question about Panasonic KX-T7736 Corded Phone (KXT7736)
HELP FOR PANASONIC KX-F2681SA
MY TELE ANSWERING SYSTEM W/FAX DOES NOT GO INTO THE ANSWERING MESSAGE , BUT GOES DIRRECTELY INTO FAX MODE ? PPLLEEAASSEE HELP URGENT .
5 Suggested Answers
SOURCE: Panasonic phone KX-TG2740: instructions
I downloaded the instruction manual, based on someone else's solution to a different question about the same product.
Posted on Dec 17, 2008
rockitman187
  • 2559 Answers
SOURCE: How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Posted on Feb 12, 2009
    • 5 Answers
    SOURCE: cant change the nite mode to a day mode
    On the phone press PROGRAM, press the original DAY button, dial the number 2, dial 781#, press AUTO DIAL STORE, pick up and drop the handpiece.
    Posted on May 22, 2010
    Testimonial: "i did what soberjudd told me and worked great. Im very happy my phone works now. Thank you."
    SOURCE: my Panasonic KX-TG2361JXB cordless phone answering
    I NEED MASTER PASSWORD OD CORDLES PANASONIC..KX-TG2361JXB
    Posted on Jun 05, 2010
    How seup fax ring
    Before selecting the ring to answer, under stand what it is..
    Press Menu button, scroll to fax set up with help of arrow keys, press ok button, scroll to answering mode. Select desired "auto, manual, fax & tele/fax.
    What are these?
    Auto: Auto aromatically tele mode will coverts in to fax mode irrespective of selected ring count. suppose if ring count selected as 4, printer will ring 4 times then stops ringing & converts in to fax mode. It doesn't matter whether it's telephone or fax.
    Manual: Printer always telephone mode. To convert in to fax mode, need to press fax button while ringing.
    Tele/Fax: Printer detects the incoming call type as tele(analog)or fax(digital) accordingly its will act. If its fax , line converts in fax mode with out any ring(silent detection), prints the received fax.If its telephone,printer rings as tele phone.
    * In auto mode only you need to select desired ring to answer(2-6 rings)
    There fore first you need to select "auto"mode, then scroll to ring to answer, press ok then select desired ring count, press ok to confirm..
    Aug 23, 2014 | HP LaserJet 3050 All-In-One Printer
    Want to change the ring setting to 6 rings before i goes to fax mode how to do it
    See the "Changing the ring setting of the telephone answering machine" section on page 60 of this manual.
    Jan 31, 2013 | Panasonic KX-FG6550 Plain Paper Thermal...
    I need to delete the message on my panasonic answering machine KX-T7730
    The KX-T7730 isn't an answering machine. You need to refer to the documentation for whatever answering/voicemail system you have it connected to. Alternatively, repost your question specifying the make and model of the answering/voicemail system.
    Jul 30, 2012 | Panasonic KX-T7730 Corded Phone
    Answering machine message
    My panasonic KX-TG5663B's screen says 9 and a little circle. The answering machine is not working. It just tells callers we are not available and hangs up. Can you assist us with this issue?
    The answering system is set for the greeting mode. It will enter this state if the message memory is full or when the caller recording time is set to Greeting only.
    To change the caller recording time from the handset, press Menu 0 6 2 then select the desired length of the recording. Then Save the setting and press Off.
    If the phone is in this state, then delete messages from the unit. Then reset the caller recording time.
    The manual for the phone is available here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/5-8-GHz-Phones/Operating-Instructions/model.KX-TG5653B.O#ts .
    I hope this helps.
    Mar 30, 2011 | Panasonic KX-TG5653B Trio Cordless Phone
    Cant change the nite mode to a day mode
    May 21, 2010 | Panasonic KX-T7730 Corded Phone
    Recording a greeting
    You need to be in Tam fax mode firstly.
    1, {#} {0} {0} {1}:= “TAM/FAX” (default)
    2,
    Press {RECORD} repeatedly to display “TAM GREETING”.
    3,
    Press {SET}. A long beep will sound.
    Speak clearly about 20 cm ( 8 inches ) away from the microphone.
    The display will show the remaining
    recording time.
    5 When finished recording, press {STOP}.
    The unit will repeat your message.
    To erase and start again
    Tam/fax mode again.
    2 Press {ERASE} repeatedly to display “TAM GREETING”.
    3 Press {SET}.
    To cancel erasing, press {STOP}.
    4 Press {SET}.
    should be good now.
    Regards
    Richard.
    Apr 24, 2009 | Panasonic KX-FPG376 Plain Paper Thermal...
    KX-FT67 new settings
    just errase all msgs or off it from settings .just off answering machine.by mian jee
    Dec 15, 2008 | Office Equipment & Supplies
    Panasonic KX-T7736 Corded Phone (KXT7736) Logo
    Top Panasonic Lands Phones Experts
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
