Question about GE JKP15 Electric Single Oven
Start button doesn't work - GE JKP15 Electric Single Oven
    Problem Solver:
  • 87 Answers
Get a new start button
Posted on Oct 14, 2010
Frigidaire wall oven CPEB30S8CC2 lower element does not work
We have a Frigidaire CPE30S8CC2 with the bottom bake element not working. We tried to replace it with no luck. The old element does not look burnt out at all. The timer, clock and broil all work just fine. The bake button works and you can set the temp. it just doesn't actually heat up at all. There are no knobs on the controls for any cook top. it is all on a circuit board for overn only. help?
Jul 16, 2012 | Frigidaire Ovens
Electrolux EOU5330X Ultrafan Electric Double Oven -
Sounds to me like the lower element shorted and tripped the breaker as it burned out. If you're handy at electrical troubleshooting that's where I'd start - comparing ohmmeter readings between the bad element and the one that works.
A wire short to the chassis would have a similar set of symptoms and be easier to find and fix.
Beyond that, you need a service tech.
Sep 03, 2017 | Electrolux EOU5330X Ultrafan Electric...
Whirlpool oven bake button doesn't work
I just unplugged it then waited and plugged it. It worked for me.
Feb 19, 2012 | Whirlpool Ovens
I have a stoves 720ef oven and cannot get rid of the auto
The handbook says:-
To cancel the automatic setting and return the oven to manual operation, press the cook time and ready time buttons simultaneously. These are the second and third buttons from the left. If you have done that and it is not working, try turning the complete oven off for awhile - say 30 mins and turning back on. If this still doesn't work then it may be that the timer/clock has gone faulty.
Nov 10, 2011 | Stoves 720EF Electric Double Oven
2 problems! Sometimes the lower oven doesn't start. U can hear the motor humming kinda but when I spin the blower wheel it'll start up and ignite. I've tested the capacitor and good. Any idea?...
I am not sure how you tested the capacitor but your issue is a classic one for a bad capacitor. The second problem is not very clear. With that being said, the wire could be grounding somewhere other than the ignitor. Please clarify a little more and I will help you work thru this.
Jun 22, 2017 | Blodgett DFG200 Stainless Steel Gas Double...
Whirlpool electric range ygy398lxpq00. The start button on the front keypad will not work. I can set temperature etc. but when I press the start button nothing happens. Shut off power for considerable...
sounds like the touch pad is bad from what you're discribing,i looked up your model on the sears site and it looks like the whole front panel comes all together,part number W10122300 and it's around 230.00 dollars.you can call your parts store and see if you can just get the touch pad and hopefully you can.i've seen this happen before,the start button is pushed alot of times and it can damage the touch pad by pressing it to hard or just from using it alot of times.http://www.repairclinic.com/PartDetail/Touchpad-and-Control-Panel/W10122300/1372156 copy and paste this,this is the repair clinic,if you buy a part from them and it doesn't fix your problem they will take it back no matter what part it is and i think it's free shipping.it's a good thing to know when the parts are so expensive,also here's the sears site so you can look up your machine.good luck with it.http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Range-Parts/Model-YGY398LXPQ00/1198/0124160/W0703148/00002?blt=06&prst=0&shdMod=YGY398LXPQ00
Aug 15, 2011 | Whirlpool RBS275PD Electric Single Oven
Lower oven will not common. The button to ignite the oven doesn't light up to start .
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 24, 2011 | KitchenAid Ovens
Cannot set the clock on my oven
It depends which model of timer, but try this.
Hold in the two leftmost buttons (of 4??) and turn the litte knob to the correct time then let go the buttons.
On some clocks you will have to press the far right and far left simultaneously 2-4 sec. to go int the set mode if this doesn't work try other combination of two buttons until the display blinks.
Hope it helps.
May 25, 2011 | Ovens
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
Missing instruction manual for IKEA Whirlpool oven FC SM6
After a powerbrake the IKEA Whirlpooloven doesn´t work, the display just says STOP and nothing works, not even the light inside the oven. This always happens after a powerbrake and usually I can fix it after some time pressing different buttons but not today. Suggestions?
Dec 17, 2009 | Ovens
GE JKP15 Electric Single Oven Logo
69 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
