Question about Samsung WF337AA Front Load Washer
Not sure if this is the right wasing machine that matches ours or not but we are getting a d5 error and don't know what it means
  • 2,272 Answers
The error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle.The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly.But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem. This has to be checked to confirm the fault.Keep updated with any more queries.Thanks.
Posted on Oct 14, 2010
  • sophielovewa Jun 03, 2011
    thanx this really helped that was exactly what was wrong. my door just had some stuff in the way thanks for the help
Door mechanism just had got loose Just tighten it and the problem resolved. thanks for the help
Posted on Dec 12, 2012
Samsung front load washer code d5
The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. the problem is related to faulty door locking assembly.There is a switch in back of door, if this fails it wont work. God-Bless!
Nov 06, 2015 | Samsung Washing Machines
Samsung rl39wbmsNOT WORKING SHOW D5 ERROR
Contact Samsung Service Center via phone and inform them about D5 Error. They will surely tell you what does that mean.
Oct 04, 2014 | Refrigerators
What is the meaning of H20 which display on ARISTON wasing machine
H2O means the applionce isnt getting enugh water but it sounds to me like youre waste hose is to far down your stand pipe it should be in no more than 4 inches and also make sure you are connected to the cold feed not the hot
May 24, 2014 | Washing Machines
D5 error
Error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly. But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.
Hope helps.
Jul 28, 2011 | Samsung WF337AA Front Load Washer
I have an f-02 fault code on my indesit evolution 1200 we12 wasing machine.do you know what this means? Julie
In my lists Indesit's 'F02' stands for 'motor jammed/ tacho problem, check leads' meaning that it is requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 21, 2011 | Indesit Washing Machines
When i try to start the washer code d5 shows ands chimes
Hi
The reason for d5 error is due to defective door lock switch. It is a door lock error code, more than likely a bad door latch it's an easy repair. When washer displays this code it means door is open while washer is running. Check the lid switch and striker.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 02, 2011 | Washing Machines
What does code d5 mean? The machine will stop and stay idle for several minutes and then start again. This happens several times per load, but eventually finishes.
Hi, The reason for d5 error is due to defective door lock switch. You will need to have this damaged mechanism replaced to fix this problem.
Apr 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error Code d5
It sound like a loose or a broken lid switch issue. The lid switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Good luck!
Aug 21, 2007 | Maytag Neptune MAH9700 Front Load Washer
Samsung WF337AA Front Load Washer Logo
3,061 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
