Question about Danby DAR483BLS Compact Refrigerator
Model # DAR483BLS. Temperature settings not working. LG light remains on ( what is that). Fridge is freezing everything.
My Temperature settings are not working, also is not cooling. The factory setting is also not working. Is there something I can do?
Posted on Mar 01, 2011
What temperature should i have my top half fridge of my hotpoint fridge/ freezer as it is too cold and everything is freezing
A good setting is in the middle of the thermostat range. For example, if you have numbers from 1 to 9, 5 would be a good number. If this setting continues to freeze, look for a bad thermostat or temperature thermistor.
Oct 01, 2014 | Refrigerators
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
I have a Kenmore Fridge Model 596-729-12200
fb4dfaa6-7995-4ceb-a384-cb74f4ab1f6a.jpgThe fresh food section has a 67003410 Damper that has a thermostat probe that senses the fresh food section temperatures and then regulates the fresh food section cold air from freezer by opening and closing to maintain a set temperature. If defective the damper may remain closed or remain closed. You can test the damper by removing and placing the temperature probe into a glass filled with ice and no water. The damper should close in the ice and open when not in the ice. I will be here to answer any questions you have, Thanks Sea Breeze
May 02, 2013 | Refrigerators
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
Wire that connects thermostat to air diffuser assembly severed
Yes, the air diffuser has to open to allow the cold air from the freezer to be blown into the fridge.
Sep 21, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Sounds like it could be a problem with the thermostat. This is what shuts the compressor off when it reachers the proper temperature.
Aug 28, 2009 | Refrigerators
Hi my fridge freezes every thing even at it's
your thermostat is bad, what it does it sense the temperature set buy the control setting, once it goes bad it does not recognize the temperature hot or coold and the unit keep running and freezes everything. thermostat work like the therometer switch, when it reach certain temperature it cut off.
Jul 16, 2009 | Dometic Refrigerators
My LG GRL207QVJA fridge is freezing everything. Changing the temperature setting on the front control panel seems to make no difference & the temperature in the bottom half of the fridge is constantly at...
I would check your owners manual but most LG only have a 12 month warranty .
check your Express or Fast Freezing Function is not turn on.
then you most like have a Thermistor/ control problem.
let me know
Apr 05, 2008 | Refrigerators
Food stays frozen regardless of temperature setting
It is possible it has a bad thermostat but most likely cause would be a bad damper motor.  It is the vent inside the fridge that opens and closes, based on temp. setting, to allow cold air from the freezer into the fridge section.
Oct 14, 2007 | Frigidaire FRS26H5AS Side by Side...
Danby DAR483BLS Compact Refrigerator Logo
399 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
