I have a technika TV & DVD 15'' combi and the cant get the dvd to play the disc spins but wont play.Any ideas please.I cant find the instruction book.
  • 998 Answers
Weak lens try to clean it using a cotton buds but wipe it gently
Posted on Oct 14, 2010
My matsui tv dvd combi says no disc and did not spinning any ideas please
Sorry but the player has failed, best choice use an external player.
Jun 28, 2016 | Televison & Video
How do I register the Technika TV That I have just bought?
What is the problem you faces with this TV? Provide more details, please.
Electro help
Electrohelponline
Aug 31, 2014 | Televison & Video
I have a dvd stuck in my Technika LCD 26-56D TV/DVD combi. Eject button on the remote control and side of TV will not eject the dvd. Screen is blue, indicating no DVD in the slot, but I can see it. Any...
Check the connection between the devices. There may be incompatibility issues. Or might the remote button not to make contact. Spread the remote, clean motherboard and contact sheet. Let them dry and reassembles.
Aug 11, 2013 | Televison & Video
Technika combi unit dvd player wont read discs anymore
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Regards.
Jan 12, 2012 | Televison & Video
Technika universal remote tr41r remote codes for technike tv dvd freview combi
Hi, I have a Technika LCD26 620 TV and ave a Technika TR41R remote contro but i cant find the code?
Any help please..
May 31, 2011 | Televison & Video
Technika tv/dvd combi dvd will not play when disc inserted it reads then indicats "no disc" and when attempting to play via start control on remote signal "err" appears
your player did not read multi disk or maybe the lens is not clean try to clean it with dvd disk cleaner first or check the disk for some scratches causing problem
May 24, 2011 | Televison & Video
I have a technika 19"
this will probrbly be a faulty laser or with it being a combo a dirty laser as they do collect alot of dust
Nov 29, 2010 | GE 13TVR60 Combo
DVD not working Technika Pro 19
The failure rate on these Technika products is shocking.
My in-laws had a 19" which gave up completely just after the warranty ran out: power supply probably.
Our 15" TV/DVD now has a DVD drive failure. Just outside warranty, and on ours we hear several loud clicks.
Inspecting the slot at the side tells us that the DVD isn't spinning.
If you're lucky it's just the lens that needs cleaning, and you could use a cleaner DVD if you can get it spinning.
Or maybe it's the motor that's failed, or maybe the bearings have seized, or there's dust in there that's preventing the motor turning.
Who knows. These things are evidently not built to last. I'll not buy another.
Jan 17, 2010 | Televison & Video
WRONG DISC ERROR WHEN PLAYING A DVD
HI,. this is a lens assembly fault. the lens is malfunctioning or, it may have stopped reading. this wrong disc code is just a universal warning that is concerning a fault if the main board doesn't receive any data(audio,video) when the disc is inserted.
Due to the integrated status of your unit, this will be a costly repair because, the entire assembly is combined together with the vcr section as well.
You will need to replace the entire assembly to fix this issue. the lens has burned out.
you can confirm my diagnosis by preforming a cleaning of the lens with a cleaning disc. if the unit continues to not read or play a CD after the cleaning, this will confirm my diagnosis.
Please rate and have a great day:)
May 23, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Televison & Video Logo
228 people viewed this question
Top Televison & Video Experts
Electro Med Services...
