Question about Fisher and Paykel GWL11 Top Load Washer
My Fisher and Paykel washer stops and beeps every time I use it EXCEPT when using it in the Permament Press mode, then it works fine. When not in Permament Press mode it gets "stuck" at the second light in the wash cycle and just beeps continuously. I shut it off, restart and set it to start at the third light and it is fine for the rest of the cycle. Any ideas on what is wrong?
  • 2 more comments
  • hannanmolly Oct 15, 2010
    Nothing is flashing. But here is what I see...
    Light one OFF.
    Light two OFF.
    Light three ON.
    Light four ON.
    Light five OFF.
    Light six OFF.
    Light seven ON.
    Light eight ON.
    When the machine is beeping, it is a continuous, regular beeping.
    Hope this helps.
  • hannanmolly Oct 16, 2010
    The model number is GWL15.
    Also, the machine works fine if in the preset "permanent press" mode. Any other wash mode and it will beep for me...
  • hannanmolly Oct 18, 2010
    My machine is an ECO model.
    When I select heavy duty with a cold water fill and low water level, I do get the same beeping. This time lights 3,4,7 and 8 were lit (not flashing).
    Also, when I use the automatic preset Permanent Press mode the water temps are set to wam and cold. I assume this means a warm water wash and cold water rinse?
  • hannanmolly Oct 24, 2010
    I am still having my problem and have no answers. The machine works perfectly when in the preset Permanent Press mode, any other setting and it stops and beeps during the same part of the cycle every time... Help!
    President:
  • 1,554 Answers
Lay the machine on its front and check the diverter valve for any debris that might be preventing it to work properly. The diverter valve is where the drain pump and the recirculation pump hoses are attached to.
Posted on Oct 25, 2010
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now what water temp are you selecting for the wash cycle,is it cold, hot or warm?When your machine beeps continuously it will light up a series of lights as an error code.These lights will be in a row of 8 lights.Starting from the left to right which lights are on when the machine is beeping,Is it the 2nd and 4th or the 3rd and 6th ---etc---?Please reply with additional information on the questions and I am sure I can help you rectify this fault.Looking forward to your reply.
Posted on Oct 14, 2010
  • luisa_sgro Oct 16, 2010
    Hi Hanna just read your last posting.Sorry to ask you these questions but the error code you indicated in your posting could be 2 different faults depending on the model number of your machine.To accurately diagnose the fault in your machine I need the model number which is located on a sticker at the back of the machine top left.Please reply with this information and I am sure I can help you rectify this fault.Looking forward to your reply.
  • luisa_sgro Oct 17, 2010
    Hi Hannan,just read your last posting.Now the error code you have indicated is called DIVERTER VALVE FAULT. This fault only is present in ECO models of FISHER@PAYKEL washing machines.If your machine is not an ECO model then the fault will be the hot valve in your machine.Try selecting heavy duty and cold water fill and low water level and put a few bits of clothing into the machine and then push start.Please reply if the machine fills and starts to wash.Also could you tell me when you push the PERMANENT PRESS button what the water temp selection is.Is it warm , cold , or hot.Looking forward to your reply.
Fisher
You need to enter the option adjustment mode:
1. Plug the machine in but do not press POWER.
2. Press and hold the Start / Pause button, then press Power
3. Three quick beeps will be heard and the machine will show an unusual pattern of lights.
4. Carry out any option adjustments necessary.
5. Press POWER to return to normal mode.
May 05, 2013 | Fisher and Paykel GWL11 Top Load Washer
Washing machine starts and stops
www.docstoc.com/docs/.../Fisher-and-Paykel-Circuit-Diagram-GWL11
http://washingmachinemanual.com/tag/user-repair-manuals-fisher-and-paykel-gwl11-top-load-washer/
Above is your service manual and a circuit diagram, Simply use the troubleshooting steps and you will soon isolate your issue and effect a repair.
May 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Sep 08, 2009 | Dryers
Fisher & paykel mw511 pride
Check the pipes actually work first. Is there a hidden drain filter that is partially blocked? Dissasemble the pump and check it works and the blades inside are clean.
Jun 13, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing machine has packed a sad
The problem is definitely in the lid switch. Your machine has a reed switch which is located under the hob on the right side of the tub. There is a magnet built into the lid which activates the reed switch when the lid is closed. You will need to replace the reed switch and harness.
Oct 06, 2007 | Fisher and Paykel IWL12 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
66 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
