Question about Vacuums
Hoover Spirit canister vac seems to overheat in about 10-15 minutes and shuts down until it cools off.
Agent Don
  • 310 Answers
SOURCE: Miele white star canister vacuum - won't turn on, but isn't clogged
Miele S251i Plus Bagged Canister Vacuum
Miele white star canister vacuum - won't turn on,...
I have the above canister vac, which after my son tried to vac the stairs, it rolled down the stairs on him, but still worked, after turned off/on. Then after turned off maybe 10-15 mins., stopped working when we tried the switch. My father in law is our fix it guy, but still having a problem with the switch. Is there a wiring guide we could look at?
Thank you!
ALevy
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can try to call the factory for the Miele S251i schematics / wiring diagram @ the phone number and website listed below or I put a few pieces of information listed below that might help.
1. The vacuum cleaner switches off automatically
A temperature limiter switches the vacuum cleaner off automatically if it gets too hot. Some models have a warning light (triangle) which comes on to indicate that it has overheated. Allow the appliance to cool down for approx. 30 mins. and remove any blockages to the air path.
2. The "Change dustbag" indicator stays on even when a new bag has been inserted
To ensure the dustbag change indicator gives a correct reading, lift the floor nozzle or power head off the floor slightly to prevent the vacuum created in the suction tube from influencing the reading.
3. The exhaust filter indicator is red
Change the exhaust filter and then press "Reset" to switch off the indicator light.
http://miele.com 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
www.AVACcorp.com 1-800-328-9430
Posted on Apr 18, 2008
Agent Don
  • 310 Answers
SOURCE: Electrolux Canister - Stops working after 1-2 minutes.
Electrolux Canister - Stops working after 1-2...
Our vac works for a short time, then shuts off and makes clicking noise as if trying to restart again. Works after cooling for a while but for another very short time. Your suggestion on fix would be greatly appreciated.
Thanks
I would advise that it could be a thermal switch or a regular switch that the thermal switch is over heating and needs replacement – there are small hoses in the door section that could have been pinched or kinked and it stopping the air flow from the vacuum – also check for a clogged or plugged vacuum hose, a full vacuum bag or a dirty vacuum filter. Check the thermal switch or reg switch or the hoses in the door. Or feel free to contact your local vacuum dealer in your area or in the yellow pages, or call the factory @ the phone number listed below:
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Don – The Vac Man
Posted on Apr 21, 2008
  • 2976 Answers
SOURCE: bosch BSA2222UC canister vacuum shuts off after 5 minutes
You have a plugged vacuum indicator port. There will be a tiny hole somewhere near the hose inlet. Just clean it with a dry toothbrush. This will allow the vacuum pressure to equalize on either side of the shut off switch.
Posted on Jan 03, 2009
  • 430 Answers
SOURCE: electrolux canister special edition problem
If this canister has a "bag full" light and auto shutoff, there is an internal diaphragm switch controlled by a dial on top of the vac. Set the dial for medium setting. Install a fresh bag and test again.
There is a pinhole in the throat of the vac which allows air to flow through a tube to the diaphragm. Check to see that it is not blocked with a grain of sand. There is a second pin hole in the corner of the bag chamber check there as well for blockage. If this vac is less than 20 years old the control valve for the diaphragm often cracks and needs to be replaced. You would access it by peeling ( like a banana) the soft rubber bumpers off the side of the vac and sliding the locking keys underneath the bumper out the front end of the vac when the bag door is open.Then gently popping the housing apart from FRONT to back. DO NOT try to pry the back housing off. Caution, this is normally performed on a cradle in a repair shop designed to hold all the components in place
Posted on Sep 07, 2009
  • 389 Answers
SOURCE: hoover cuts out after 5 minutes and will not
OK - so it cuts out because it's overheating. The cause of this is almost always a blockage. You don't say what model of vacuum this is, so I can't guide you where to look. If you've got flexible hoses, check them. Also check all filters and any other airways you can get at. If you are 100 percent sure that everything is clear, but the problem persists, then the motor's at the end of its useful life.
Posted on Sep 12, 2009
I have a Hoover wind tunnel that suddenly stopped working when the cannister got full. Once emptied still would not start. Anything to fix this? Does it have an automatic shut off when full?
If the airflow is restricted the motor will overheat. Most vacuums have a thermal heat sensor built into the motor which will shut the motor off until it cools down.
Jan 05, 2017 | Hoover Vacuums
Mini shop vac
There is a hidden thermo fuse in the tape on one of the field windings. If it overheats that fuse will blow and the motor won't run until replaced.
May 22, 2013 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vaccume shuts off after 5 minutes of using. will only start after sitting for hours.
This sounds like an overheat condition. You must have plugged air flow, so rather than cause a fire, the unit shuts down until cooled. Find and remove the blockage << Not always an easy task.
May 21, 2011 | Hoover U5753-900 WindTunnel Bagless...
I have an older Electrolux canister vacuum - model #2100 and the temperature sensor shuts down the motor. How to I take apart and clean?
Check to be certain the thermo lite is on and not the bag full indicator. The thermo detector is very reliable, but the bag fill valve often fails. If it is the thermo, check your hose and wand for blockage by dropping a coin through them,before opening the vac itself.Otherwise you may have a bad set of motor bearings causing the motor to overheat due to its age.
The 2100 and all its canister cousins made since 1982 seem to be prone to failure of the dial valve on top cracking internally. The causes the bag full indicator to come on and the vac to shut down.
To open the vac you will need to slide the locking keys and bumpers forward with the bag door open. Do this with a set of pliers. Once done the vac will open from front to back like a **** shell. Be careful to look at the underside hinge are of the bag door before separating and mark and locate the wiring harness . This vac only goes back together one way, perfectly assembled it pops together with ease. If any piece is out of line it`s like a RUBIKS Cube. Take your time . OEM parts are only available through an AERUS Elctrolux dealer or repair shop
Dec 14, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Hoover upright has stopped working and tripped the circuit breaker. Where is the fuse located on the hoover ?
Most Hoover uprights do not have fuse. Some canisters doe but it is a thermal shutoff. When the vac overheats and cools down it restarts on its own.
You very likly have motor damage, but if lucky you could have an obstruction in the fan causing a jam. Do not attempt to run again.Lift the lid off the vac and see if the drive shaft for the belt will turn. If not motor will need to be removed and fan housing and intake area inspected. If the motor shaft turns and you hear scratching or clicking, the carbon brushes are likely damaged often requiring a replacement motor. If the fan is jammed you will need to dismantle the fan housing. Remove the two motor clamps and there will be four screws on the side of the housing to release the fan cover. The fan should rotate freely in your hand.
Sep 13, 2009 | Vacuums
Hoover Cyclonic Fusion Vacuum overheats and shuts off.
If it gets too hot it will shut down for about an hour...it does that to protect the motor. A lot of tools and work appliances seem to have that feature nowadays.
Jan 09, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
No pwer
Our Hoover U5780-900 stopped working while using the attachment. We let it cool down for about 5 minutes and it fired back up. It appears to shut down when it overheats.
Nov 14, 2008 | Hoover U5780-900 Windtunnel Cyclonic...
Hoover wind tunnel
Did you check down by the brush roll for a clog in the dirt inlet. And is the brush roll turning freely, if it is being lugged down, it can cause the motor to overheat and the thermo protector will caught it off, until the motor cools down. But if both are ok, then maybe the motor protector needs to replaced, it is prematurely tripping.
Jun 19, 2008 | Vacuums
I have an upright, but use it as a canister. It will start sometimes and vac for about half and hour and then it will quit. I can't get it started again even after it cools off.
First check the hose and down by the brush roll for a clog. If there is a clog, it will cause the motor to overheat and the theremo protector will cause the motor to shut off until it has cooled. Now if it won't turn back on, the thermo protector may have gone bad, or the motor itself has gone bad.
Jun 14, 2008 | Electrolux Vacuums
Hoover Mach 5 sweeper
Hey all...
Had this same problem with my Mach 6 (same as Mach 5)
It would shut off after 15 min of use. What is happening is the secondary filters, HEPA and the canister all need to be cleaned. This is vital. What the vacuum repair people are keeping from you is that tidbit of wisdom. This particular vacuum is picky about airflow. Pull the canister, and on the body of the vacuum on top of where the canister sits are the secondary filters. There should be a sticker explaining how to remove them. Clean them throuougly, mine was filthy. Make sure you clean the canister by unlocking it and cleaning out the micro holes and the cone end. Mine was completely plugged. Now brush the dirty side of the HEPA filter with the combo tool. Let the secondary filters dry completely (you can blow dry them on cold) Re-install everything, and the vacuum will run like brand new. I vacuumed the whole house after I completed this maintainence and it works like a champ. Don't return this vac until you clean it completely.
Jan 28, 2008 | Vacuums
Open Questions:
Vacuums Logo
37 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
