Question about Viking Air Tools Dual Piston Straight Line Sander
TIMING ON MY VIKING AIR FILE. - Viking Air Tools Dual Piston Straight Line Sander
    New Friend:
I need to know how to set the carrior plate to the tool
Posted on Jun 07, 2013
Husqvarna sewing machine - viking 400
HI,
Do you mean how to retime it?
Jun 11, 2008 | Husqvarna Viking 1
The timeing is off on my model 6440
Timing will need to be set by a Service Tech since it involves removing the covers and using a timing set tool. You can find a Viking dealer near you using the link "Locate a Dealer" at the Husqvarna viking website -
http://www.husqvarnaviking.com/us
Oct 16, 2014 | Husqvarna Viking 1
WhyHusqvarna viking emerald 116 bobbin thread won't thread through?
The needle is not always picking up the bobbin thread. This sounds like a hook/needle timing issue that will require service by a Viking Service Tech. Suggest that it be serviced by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Jun 30, 2014 | Husqvarna Sewing Machines
Viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Jan 19, 2010 | Husqvarna Viking 1
Thread balls up underneath my feed dog when straight sewing. Why?????
Could be needle/hook timing. With machine off do the following to check timing -
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area and thread cutter area, removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding counter clockwise when going through the bobbin case.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to sew without thread balling up, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 24, 2009 | Husqvarna Designer I
Bobbin thread won't feed husqvarna viking sewing machine
sounds like hook to needle timing has shifted. Take to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you.
Sep 14, 2009 | Husqvarna Viking 1
My Viking Husqvarna Lily is not picking up the bobbin thread. Any ideas?
did the machine break a needle or get jammed up prior to this? is the needle inserted correctly and all the way up in the holder? are you threading the needle front to back?
it sounds like a timing issue but this would not have gone out of timing on its own - it must have broken a needle or been stuck for timing to go out. if it is timing it could be the timing belt has slipped a couple of teeth, or the hook screws may have allowed it to shift.
if it is timing it requires a tech to repair
goodluck,
scott.
Jul 17, 2009 | Husqvarna Viking 1
Viking sewing machine programmable card
Programable cards do eventually pack up. Test it with your reader writter.
Jun 17, 2008 | Husqvarna Viking 1
Mar 06, 2008 | Husqvarna Viking 1
Viking Air Tools  Dual Piston Straight Line Sander Logo
660 people viewed this question
Top Viking Tools & Hardware - Others Experts
Are you a Viking Tool and Hardware - Other Expert? Answer questions, earn points and help others
