Question about Gateway Computers & Internet
Hello, I recently purchased the 12-cell battery for the Gateway NV5214U which I upgraded from Vista to Windows 7. However the laptop does not recognize it. It says to remove the battery as it could potentially damage the laptop and then it shuts down. Do you have any reason what could be the cause of this ? How do I fix this problem? I am sure it is a fixable solution. Could it have anything to do with the differing voltages on the 12-cell battery vs. the 6-cell battery that originally came with the laptop ? Looking forward to your response.
  • Alexander Knowles Oct 14, 2010
    Thank you for this response. I believe that the voltage may be the issue as it higher than the original. The original 6-cell is 10V and the 12-cell is 11V. You would think the battery companies selling them would ensure they remain the same to avoid these type of issue.
    The BIOS is already updated so that is a non issue. The only thing I can do at this point is to search and see if there is a 12-cell battery with a 10V capacity.
    Thanks again for your help.
  • 2,567 Answers
First, you will need to check the voltages of the 2 batteries & make sure they are identical. Both batteries should have identical voltages. The only difference should be that 12-cell batteries last longer than 6-cell batteries.
Next, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
And last, if none of this works, then try updating the BIOS. Sometimes this solves problems with the battery not being detected. You can download the BIOS for your model from Gateway support site. You have to download the BIOS for your exact laptop model. I would also recommend to do some research on the Internet before updating the BIOS to see if somebody else encountered the same problem on the same laptop model, & whether it was solved by flashing the BIOS or not. Beware not to turn the power off while flashing the BIOS, or you might render your laptop unusable.
Posted on Oct 14, 2010
My gatewaylt2802u i cant find its webcam
Open the Device Manager, Imaging Devices, is it there? Scan for hardware changes. Open Windows Updates, install all updates. Search Gateway website, select your OS 32 or 64bit: http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2373 Download driver for webcam. You may have to use the Vista driver. Change compatibility to win 7. What was the OS originally?
Dec 20, 2012 | Gateway NV5214u Notebook
I upgraded my GATEWAY MX6959 LAPTOP memory from 1gb to 2gb speed 667mhz and 6400 i researched and it said it would work, i had windows 7 ult installed after memory upgrade it wont boot up and ask to
Have you ever booted in win7? It may be a win 7 issue not a memory issue. Does it boot with the 2 512 MBs of memory. unplug, remove battery, install the 512 MBs memory, reboot.
Dec 17, 2012 | Gateway mx6959 core 2 duo 1.66ghz 1gb...
What's your problem?Hello, I have upgrade my laptop battery to a 12 cell battrey. the instructions that came with the battrey say that it requiers bios update in order to work in my acer aspire la
One last note:
I did find a 9 cell upgrade battery that will work.
Battery - 9 cells 7800 mAh, 11.1 V Part # LB-AC20-07800-01
from http://www.laptopbatteryone.com/
Acer Aspire 5735z. I am running.. OS Windows 7-32 bit & bios V1.08
Dennis
Jul 24, 2012 | Acer Aspire Computers & Internet
What's your problem? I have upgrade my laptop battery to a 12 cell battrey. the instructions that came with the battrey say that it requiers bios update in order to work in my acer aspire laptop 5
Download the BIOS upgrade and device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
I own a Gateway NV54 computer that operates Windows 7. Recently my computer will only work when plugged in and my battery is not charging.
This is a sign that you need to purchase a new battery. The old one will not hold a charge anymore.
Good Luck
C2Solutions
Feb 17, 2011 | Computers & Internet
Hello, I recently purchased the 12-cell battery for the Gateway NV5214U. However the laptop does not recognize it. It says to remove the battery as it could potentially damage the laptop and then it shuts...
cells in batteries are rated at 2.2 volts a cellm so 6 cells = 13.2 volts
if you have a 12 cell battery that would = 24 volts
get a multimeter and check the voltage across the positive and negative terminals
May 21, 2017 | NetGear RangeMax Premium Wireless-N...
Update to windows 7 on Gateway M-1624 Notebook with vista
You can upgrade to windows 7 from Vista is pretty straight forward. All you have to do is put Windows 7 CD in while running Vista and automatic startup should show you options to choose. There's some trouble with it sometimes for example, you can't upgrade a 32-bit version of Windows to a 64-bit version, or upgrade from a higher edition of Windows, such as Windows Vista Ultimate, to a lower edition, such asWindows 7 Home Premium. If this is the case, you'll need to use the Custom option during installation. Please remember that while Upgrading will keep all of your files and programs, custom installation will NOT. So you would need to back everything up before you start. Before you install Windows 7 make sure that all of programs that you need will work on it. For more information visit this microsoft website dedicated to upgrading to windows 7 >> http://windows.microsoft.com/en-US/windows7/help/upgrading-from-windows-vista-to-windows-7 Have a nice day and good luck.
Apr 17, 2010 | Gateway M-1624 Notebook
Upgrading windows xp to vista
You can upgrade from your current edition of Microsoft Windows XP or Windows 2000 to a corresponding or better edition of Windows Vista by purchasing and installing an upgrade copy of Windows Vista.
While selecting the edition of Windows Vista that's right for you, it's important to clearly understand what hardware your PC will need to ensure the features you want will run reliably.
Nov 16, 2007 | Computers & Internet
Computers & Internet Logo
96 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
