Question about Kenmore Dishwashers
Kenmore Model Ultra Wash Model 665- 45955 Problem: Dish washer leaks at bottom intitially during sudding cycle only...first 5-10 min... then no leaks/drips thereafter thru balance of clean/rise cycle. Whats up....Thought possible seak around washer door is bad but no leaks at bottom or elsewhere after the sudding cycle is completed. Please provide complete resolution reply if possible Tx
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If you have water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference. Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. You should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses. Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear). Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson. An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 14, 2010
I have showing 5d does not spin what does it mean
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Jan 04, 2015 | Kenmore Washing Machines
My dishwasher (model # DU81ODWGU1) is leaking water and suds during the wash cycle. I ran out of dishwasher powder so I had used regular dish soap for this cycle. Did this cause the problem? My...
MOST DEFINITLY You can put regular dish washing liquid in a dishwasher will do that every time take a few washings to stop run 2-3 times empty it will stop.
May 06, 2011 | Whirlpool Dishwashers
How to fix suds lock on Kenmore
The Sd code on most Kenmore Elite HE washers indicates a suds lock (usually caused by excessive suds do to overuse of detergent). Check for the presence of excessive suds in the washer. If you see a lot of foam, the code is likely caused by this problem. You will likely be able to drain the washer and spin out the clothes once the suds dissipate. Run an empty cycle with 1 cup of liquid chlorine bleach through the washer to help rinse out suds residue. If you see foam emerging during the empty cycle, you may need to repeat this process. You can also use Washer Magic or AFFRESH to help clean suds residue out of the washer. These products are available at your local Sears store or the grocery store. Make sure that you are using HE (High Efficiency) detergent in the appropriate quantity. You may need as little as a tablespoon of detergent in a high efficiency washer due to the low water level. You may need even less for a while since the clothes will likely have detergent still dissolved in the fibers that will emerge during subsequent wash cycles.
There are many different models of Kenmore Elite HE washers. If you do not see any apparent problem with excessive suds or need more help, resubmit your question with additional details and the full model number of your Kenmore Elite HE washer.
Jan 11, 2011 | Kenmore Washing Machines
I have a Kenmore Elite HE 4t front load washing machine. Code F ud is currently flashing and the door won't open. I've tried canceling but it just beeps and keeps flashing this code.
Remove the bottom panel. The tech sheet is located beside the white box to the left.088d3fc.jpg It gives diagnostic directions and failure codes. Suggest you clean the dispenser area up04f0b28.jpg and use the correct amount of HE detergent.
Seems to me like that is a suds detect:All front load washers require "HE" detergent (a low suds type detergent).
There are three commonly sold concentrations of HE type detergent.
HE : (2) Tablespoons Per Wash Load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated) : (1) Teaspoon
Most consumers follow the directions on the bottle or box of detergent--which is normally the correct thing to do. However, the amount recommended in nearly all brands of HE detergent are excessive & incorrect.
Additionally---using the correct amount of HE detergent will end issues with:
1) Musty Odors
2) 'LE" Errors (that can cleared by unplugging the washer)
3) L-O-N-G cycle times (longer than time displayed).
A 51 minute cycle can take 120 minutes to end.
4) Insuffificent Cleaning Results
5) Small water leaks behind the washer at the air vent.
(Suds oozes out during the spin cycle)
May 19, 2010 | Kenmore Washing Machines
Washer goes through 40 min. cycleand stays on 1 min. spinning and rinsing for another 30 min
your using way to much soap
during that whole 1 minute cycle it is detecting suds and trying to rinse the cloths further
cut way down on the soap here
you should be using 1 tablspoon per load
wash one load without anyy soap at all
this should help to reduce your suds lock
Oct 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore washer elite problem
Sud
SUDS LOCK (Overdose of detergent detected during the wash cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If “Sud” is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
A. If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
B. Check the drain hose and make sure it is not plugged or kinked
C. Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
D. Check / Clean Drain Pump Filter of foreign objects
E. Check Drain Pump
F. Check the Pressure Switch
G. Check CCU
Replace failed component.
Aug 29, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore under counter ultra wash dishwasher model 665.15825691 has started leaking at the lower corners of the door. The leaks seem to occur during the final rinse while the water is being heated. I...
Happened on my dish washer too. Remove lower rack, remove lower spray arm by removing the center plastic nut, check screws (torx) on outside edge of pump. Tighten these as necessary, mine were loose causing water to spray forward against the tub causing leakage.
Jun 27, 2009 | Kenmore Dishwashers
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Dishwashers Logo
136 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
